Intercooler chiller info?
Old Jun 19, 2006 | 11:44 PM
Armyman2445's Avatar
Default Intercooler chiller info?
Anybody running an intercooler spray bar? If you are, what kind of gains are you seeing from it?
Old Jun 20, 2006 | 10:00 AM
HAMRHEAD's Avatar
I'd like to know as well!
Old Jun 20, 2006 | 10:48 AM
FormulaFire's Avatar
From what i hear.. most people say not to run them.
Old Jun 20, 2006 | 10:57 AM
sytyjedi's Avatar
The gains are absolutely zero. I have seen super trick Syclones with CO2 spray bars, Supras that open a 10lb bottle and let 5lb of it go right onto the IC, etc. etc. All saw absolutely no ET improvement.
In most of the cases where a car would see a gain on a dyno it is actually the nitrous getting into the motor thru the IC via small hole or leak.
It is a neat toy and a good idea that would seem to work, but you are really just purging your nitrous system at a different location than by the winshield. Both waste nitrous and give you no gain.
Spend the $$$ elsewhere. Don't be "that guy" that tells everyone not to do it after they wasted $$$. Unless you are builidng a car for F&F...
Old Jun 20, 2006 | 11:04 AM
That pretty much what I heard.. If you want to run Nitrous. Put a small(say 50 shot) after the intercooler. Before the intake manifold. The gains will be about 100rwhp on FI.. And you'll getting some cooling properties from N20. Pretty much on the opposite end.. Still has cooling properties but reacts differntly with the ambient temps.. Is methanol. Won't see much hp gains from that.. but it wi;; keep you from detonating and allow you to run higher boost on pump gas.. etc etc
