F1 procharger????
-low CR 408
-Dart 240cc Heads 350I 290E .600
-F1 kit w/ twin intercoolers
-Blower cam
-Open exhaust
-fuel modifications needed
I would like to get 1000RWHP out of this set-up is there anything I should change to achieve my goals? Will I need a FMIC? or should I go with no intercoolers and do meth?
*edit* Will the stock MAF and MAP be sufficient, or are there alternatives that I should be looking into?
I am hoping for 850+ on my F1C blower/408 setup I am building right now.
Not sure if you can get 1000rwhp with pump gas. Wll probably need to increase the C.R. a bit to gt a bit more out of it but if 1000rwhp is your mark, youmight need to go into the F2 arena. Now, 850rwhp is enough to get you well into the low 10's, high-mid 9's, depending on car's setup so it could be a good start.
60' 1.58
N/A 11.1 @ 121
No2 10.2 @ 135 lifting the wheels twice
N/A 428
No2 667 Dual 52's (dry)
60' 1.58
N/A 11.1 @ 121
N/A 428
i could of sprayed my old setup, 408ci making 460rwhp to the tires, stalled, unlocked, and would of made that or a high 10 with about 500 more lbs. than you, but, what fun is in that? Cheap times, and that is not my bread and butter.
Second, what the hell are you talking about, this post makes no sense.
heres one of them, doesnt say what kind of power hes gonna make, but im sure it'll be plenty
i never questioned your cars potential, im sure it runs good for what it is..... but not my choice of poison and refilling the bottle gets old really quick...
".... I'm running an F1R, 408CI... pullied for 15-20lbs peak boost.
Seriously. What in the **** are you talking about? I am now dumber for having read (and subsequently trying to make sense of) what you posted.
