Lets talk some about the affects of compression..
with forged internals it should be a walk in the park! if a stock motor can doit with thin heads and weaker pistons and rods, why the hell cant a forged motor take it???
does the outside air temp really have that much effect??? meaning you have to drop compresion over 2 point?????
Chris.
D1SC 17 psi, 8:1 Compression, 383ci, 697/641 HP/Tq, 2.5 years (mine
)D1SC 15 psi, 9:1 Compression, 346ci, 711 HP/600 HP/Tq, 2ish years
D1SC 10 psi, 10:1 Compression, 346ci, 500ish/500ish HP/Tq, 2ish years
TT 12 psi, 9:1 Compression, 346ci, 550ish/550ish HP/Tq, 1.5ish years
There are more, but you get the general feel for what works.
Chris.
General rule of thumb is don't beat on the car when it's hot out.
Now that i'm 8.7:1 I'm able to run 15psi on 91 even in our 100+ temps. I wish my compression was 8.0:1 though, more boost on 91... or at least more safety margin
9.5:1 is not high compression folks.
John
From all my datalogging on my Honda, DSM, and Turbo mustang, compression makes absolutely no difference in how the turbo spools, in terms of motor speed. In terms of actual time you might get a tiny advantage because of more horsepower to accelerate the car through the rev band to hit said RPM level to make boost faster, but the difference in my mustang between 11:1 when it still had the nitrous pistons in it and 8.3:1 with the low comp turbo pistons in it was not noticeable on the street. The 8.3:1 motor made as much power on ~8 psi as the 11:1 motor did on 6, which really isn't a huge difference if you ask me. The big difference? The 11:1 motor was knocking on pump gas past 8, whereas the 8.3:1 setup would take 17+ on pump gas no knock.
My new turbo motor is 414 inches (4.125 x 3.875) and 7.8:1 static compression. A healthy solid roller cam. 527 ft-lbs of torque at 3500 RPM's on an engine dyno. Now, you decide if a 408 really needs any more compression to make it lively on the street at low RPM's
It makes 8 pounds of boost on a pair of 76mm turbos by 4000 RPM's on the street, 17 psi rolls in around 4500, and it will peg the 30 psi boost gauge before 5000. Those are about as big of a turbo as you can put on a motor for the street, and the low end is perfectly fine with my "dogged" compression. Only difference between my car and a 10:1 car? I fill mine up at Shell. My car will run ALL DAY in 100 degree heat boosting the ever loving **** out of it, I can dump another tank of 93 octane in it, and it won't skip a beat.I'm all in favour of low compression, especially running a 400+ inch motor.
so i guess high comp and high boost can be done but is harder to do than droping the comp and running a little more boost! so whatcomp would you guys recomend on a pump gas only strret 346 running 15psi??
thanks Chris.
and higher cubed motors can get away with lower compression. on a 346 at 15 psi id prob go 8.5-9.0 maybe a lil more but unless the tune was dead on id suggest using methonal. Plus I hope your talking about a forged motor as well.
