Front Mount or Meth. Injec.
Old Jun 28, 2006 | 10:28 AM
JD_Z28's Avatar
Default Front Mount or Meth. Injec.
What Provides a better cold air charge.
Old Jun 28, 2006 | 10:32 AM
67Firebird455's Avatar
Depends on the size of the FMIC. Meth is very popular but you risk failure and high IAT's because of it. I went FMIC on mine, plan to add meth also with the new build.
Old Jun 28, 2006 | 10:41 AM
98turbls1's Avatar
I would say to go with an intercooler for the street John...Then if you wanted to up it more you could go with the meth but you just run a risk of the injection failing...There are no mechanics in the intercooler which obviously have a higher reliablity...
Old Jun 28, 2006 | 11:14 AM
Boostaholic's Avatar
Intercooler
Old Jun 28, 2006 | 11:19 AM
JD_Z28's Avatar
Thanks for the replies, im gonna go with FMIC that TRT supplies for the STS kit, Its seems to be a good deal for everything.
Old Jun 28, 2006 | 11:22 AM
If you still want more boost after the FMIC you can always throw a meth kit on later Thats what I'm planning on doing for pump gas.
Old Jun 28, 2006 | 11:27 AM
98turbls1's Avatar
Me too...
Old Jun 28, 2006 | 11:29 AM
killerbeez's Avatar
Hey i haven't really looked into fmic's for the sts, how much is one on average? and where can you get a trt?
I haven't looked at 'em cause I was plannin on just 5# with stock motor and compression, but i may rebuild the bottom end so more boost and fmic is a possibility now
Old Jun 28, 2006 | 11:31 AM
98turbls1's Avatar
TRT is a sponsor on here that has a complete FMIC package for the STS owners...You should check them out...
Old Jun 28, 2006 | 12:43 PM
JD_Z28's Avatar
Billy from TRT sells the kit with piping for a really good price check him out.
Old Jun 28, 2006 | 12:51 PM
longrange4u's Avatar
Billy (TRTPerformance) is the bomb! Call him!
Ok without jacking the thread.... what is the largest FMIC that you can put in an Fbody?
Old Jun 28, 2006 | 02:55 PM
trtturbo's Avatar
Jared, we can just upgrade to a 4" that will support 1000 and it fits just like the one you have. I will just strengthen the bracket for the added weight.
We can talk about you just trading your intercooler in toward the larger one and you just taking care of the difference.
Old Jun 28, 2006 | 10:11 PM
Julio's Avatar
The downside to the front mount is pressure drop across it, meaning you dont get out what goes in. Depending on core can vary a few PSI. Then is the issue of not allowing air to the radiator, on a street car with AC.. this can be an issue. Heat soaking can also occur..
IMHO, get a small front mount with a nice high flowing core... large pipes.. then latter do the meth for higher boost and slam that air charge down below ambient.
My rule of thumb is anything less than 20 PSI can get away with methanol injection... but the higher the temperature load, the more meth that will be required to get the temps down... not a good thing since reliance increases many fold, as does consumption.
HTH
Old Jun 28, 2006 | 10:54 PM
onfire's Avatar
Coal Mining Director
HTH
Hey Julio,
Quit posting here and send me some parts
Great guy to work with.
Tom d.
