What does hi-fi mean and will this turbo work?
Old Jun 26, 2006 | 10:04 AM
bowtieman81's Avatar
Default What does hi-fi mean and will this turbo work?
OK, searched and looked and have not seen what hi-fi means, like what is a T60-1 hifi?
Also, I am getting a used TTi street kit and am wondering if this turbo will work with the kit. I know most guys recommend the T76, but this seems like a decent alternative in terms of value (used T60 = $375 or less, new T76 = $1350).
http://turbotechnologyinc.com/tbay.htm
scroll down to the T60 turbos
Old Jun 26, 2006 | 03:01 PM
SUPER DAVES Z's Avatar
If money is a concern just go with a a Master Power T70. You can pick one up for 525-575 and get an oncenter .96a/r exhaust housing off ebay for around 50-75. Atleast with the T-70 you can make more than 500rwhp, for not too much more $$$
Old Jun 26, 2006 | 03:26 PM
Thanks Dave. I would really like the T76 that TTi uses, but they want $1350 for the turbo. Seems a little high to me. I would just get a regular T76, but I don't really want to cut into my car frame.
Your idea about the T-70 seems like a good alternative.
Also, still wondering what is hi-fi.
Old Jun 26, 2006 | 03:32 PM
Originally Posted by bowtieman81
Thanks Dave. I would really like the T76 that TTi uses, but they want $1450 for the turbo. Seems a little high to me. I would just get a regular T76, but I don't really want to cut into my car frame.
Fits perfect and can make ATLEAST 530rwhp (is good for more than that, just what my old car made with one at 10psi) with a tti street kit.
Don't know if Jose still carries them, if not you can find plenty for sale on Turbomustangs.com, through various vendors.
Good luck!!
Old Jun 26, 2006 | 03:55 PM
Dave, what size log and crossover did you have on that setup? I am assuming you had a 3" downpipe, correct?
Also, I have read that the MP T70 will spool pretty quick due to its light weight shaft. Is that you opinion also? What rpm did you see full boost at?
Thanks for answering all my boob questions.
Old Jun 27, 2006 | 11:14 AM
I had the older log (not the new one Ryan is running) with a 3" DP. I'm not sure of the size, but it's probably the same as the used one you're looking to pick up. I had a crossover that went under the trany (that was 2.5"), just don't lower the car if you have a 6 speed or it will drag.
The T-70 spooled really quick and had full boost by 3000 rpm, but any front mount kit with a T-76 or smaller will spool instantly on an LS1 when you're above 3500rpm.
Later
