Will these rods work?
Old Jun 27, 2006 | 02:17 AM
red90cobra's Avatar
Default Will these rods work?
http://cgi.ebay.com/ebaymotors/Eagle...spagenameZWDVW
the reason i ask here is because this section has alot of knowledge. the pistons use .927 steel tool pins and it's a stock crank. yes i know it's a 6.250 rod. just need to know everything mates up.
Old Jun 27, 2006 | 11:57 AM
67Firebird455's Avatar
Shoot man, wish I could help you out, I have NO idea when it comes to Ford stuff... =( TTT for ya, good luck with your project!
Old Jun 27, 2006 | 12:11 PM
red90cobra's Avatar
it's say for either or sbc or ford i just don't know what the stock crank pin size is. anyone recommend some road bearings?
Old Jun 27, 2006 | 12:39 PM
GrahamHill's Avatar
Although im probably needing a math refresh on these formulas, wont that leave you an 1/8th" to tall for the deck height? Wouldnt the compression height need to be like 1.169 on stock stroke?
Old Jun 27, 2006 | 01:15 PM
red90cobra's Avatar
my compression hight is 1.103. I was going to run a 6.3 rod but I needed to lower my compression a little bit because of the dome pistons. and it should be in the hole. with a 6.250 rod can anyone check the math for me please.
Old Jun 27, 2006 | 03:59 PM
GrahamHill's Avatar
.066 down if the deck is 9.23
Old Jun 27, 2006 | 04:21 PM
red90cobra's Avatar
cool deal. the set of rods with l19 bolts are only 470 out the door.
Old Jun 27, 2006 | 05:27 PM
GrahamHill's Avatar
Someone check my math though, lol. I dont even trust me sometimes!
