Taking S/C off
Old Jun 27, 2006 | 01:46 PM
TylerDurden28's Avatar
Default Taking S/C off
How bad will my car run w/o it tuned again after the s/c is off. Also would I need swap out the 36LB SVO's to the stock ones again? And final question...would it stop my car from running rich or is that another problem if I take out the s/c?
Old Jun 27, 2006 | 02:04 PM
EPP's Avatar
EPP
Smile
If your car is currently running rich, it needs to be tuned. If your car is already running good and you remove the ProCharger, you will probably get by with it just the way it is for now. You will still want to have the tune checked out eventually just to make sure the air/fuel ratio is within range. Bob
