Bypass valve on automatic?
Old Jun 29, 2006 | 06:56 PM
adrenalineaddiction's Avatar
Default Bypass valve on automatic?
Procharged Lt1 8 lbs with Th400.. Do I have to run the bypass valve? I did a search and found several places that say no. Is this true? Thanks in advance
Old Jun 29, 2006 | 07:39 PM
FUroundeye's Avatar
I know a lot of the Turbo Buick guys don't run BOVs.
Old Jun 29, 2006 | 08:29 PM
thats where i read most of the no's.... keep em coming guys.. thanks again
Old Jun 29, 2006 | 08:55 PM
andereck's Avatar
Yes you really do. When you let off the throttle the air has to go somewhere. With no bypass it will overrun your throttle, blow off a tube, expand an intercooler tank, or exit through the inlet of the blower (and possibly be re-read by the maf). When a large volume of air flow backwards through the compressor it will try to change its direction of rotation. That's not a happy situation. Its very important for an automatic because the engine rpm doesn't just drop back to idle on decel - no clutch.
Old Jun 29, 2006 | 09:10 PM
That was my thinking to and thats why I asked the question... thanks for the info..
Old Jun 29, 2006 | 10:15 PM
BIG BAD BLACKSS's Avatar
Im wondering if my wimpy looking stock procharger bypass/bov whatever it is, wil handle a high boost situation with an automatic? Would that be something i hsould be looking at upgrading?
Old Jun 30, 2006 | 04:55 AM
EPP's Avatar
EPP
Question
It depends on how much boost you are planning on running. We have used the newer standard Proflow valve at 14 to 16 psi, with no apparent problems. Bob
