Turbo Oiling Problem!!!!!
Old Jul 13, 2006 | 09:32 AM
trtturbo's Avatar
Originally Posted by MiaSSmaro98
damn that good to hear u fix the problem were did u buy that check vavle?also trt will i need this for an engine bay turbo?
Using the check valve is because where the turbo is on the STS it is low and allows oil to drip into the turbo. Mounted higher, you should be fine w/o, although you may need a restrictor.
