Help me with a filter location issue
Old Jul 12, 2006 | 02:25 PM
TrakDay's Avatar
Default Help me with a filter location issue
So I went ahead and put an F1C Procharger on my car. The new motor is not here yet, but I need to do something about a filter on this blower because I do like ot drive the car on the street.
Picture of the D1SC setup with the filter
Pictures of F1C... where and how can I route piping to get a filter on this thing?
I am thinking if I replace the coolant reservoir with something smaller and tuck it away I can possibly run a silicone hose and get a filter mounted right there. But I need to know if anyone else has an idea? Getting the F1C in the damn GTO bay was hard enough, now getting a filter on it is going to be even harder...
Old Jul 12, 2006 | 03:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
The shorter the pipe 'tween the blower and the filter the BETTER. Best scenario would be the filter right off the blower.
Old Jul 12, 2006 | 03:55 PM
stevieturbo's Avatar
The GenT single turbo kit, mounts a small coolant reservoir over on the right side of the car.
Seeing as the main pipe comes from that side anyway, re-locating would be the sensible option.
Although the filter is then placed in a hotter location than if it was up front.
Old Jul 12, 2006 | 04:29 PM
TrakDay's Avatar
OK... How about this. Swing the filter up front like the D1SC setup but run a filter in the fender well, so cut a hole where the filter is located and go straight into the fender well. Use that for daily driving. And then would I be ok with just a screen and no filter when I am at the track? Would that help make anymore power or would that just be a bad idea?
Hell this filter setup will probably be easier than trying to get my new larger FMIC setup... LOL
I just wish I had teh car here in my garage right now so I could begin working on fabbing all of this misc stuff up before my motor arrives. New tranny/DS should be in by the end of the week.
Old Jul 12, 2006 | 04:53 PM
Some of the Procharger kits EPP have posted photos of here, drilled a hole through the inner wheel arch, and placed a filter down there.
Although it may pose a restriction due to the plumbing, the thought of cool air always being ducted in would surely be worth it.
My own setup is similar to yours, although I do have room for a large filter behind the blower ( ie attached directly to it ) Pic below. Obviously mine isnt a GTO, but aside from the strut tower on your car, space is also tight.
http://gallery112848.fotopic.net/p30843459.html
I'd guess with the coolant reservoir removed, you would almost have similar room to me I know Ive looked at a mates CV8 Monaro, and thought we could squeeze a decent filter in, as it will be receiving a YSi later this year too.
I dont have the room to mount one infront/ or to the side like yours though, or in a frontal location that would source cold air.
Methanol injection takes care of that now though.
I wouldnt run the risk of no filter at all.
Old Jul 12, 2006 | 06:45 PM
Slowhawk's Avatar
LS1Tech Sponsor
I'm thinking some sort of custom air plenum that follows the same route as before but it won't be round.Sheetmetal a box through the opening.
Old Jul 12, 2006 | 07:00 PM
TrakDay's Avatar
That never even crossed my mind! Thats actually a great idea. Should I take it into the fender well or what?
Thanks for the help so far guys!
Old Jul 12, 2006 | 08:30 PM
Slowhawk's Avatar
LS1Tech Sponsor
Hard to tell by the pics.I would probly try to run it the orig. way if it can be done.
Old Jul 13, 2006 | 05:02 AM
EPP's Avatar
EPP
Mick, take a look at the way we modified the stock ATI GTO inlet on the Mazda RX7/LS1/GTO ProCharger kit that is in the project car section of my website. Possibly it might help you out. Bob
