Lean rear cylinders with boost?
Old Jul 13, 2006 | 02:00 PM
Sound Performance's Avatar
I would definitely run 11-11.5 a/fs. 12.5 puts you right at the edge and the power difference is not worth it.
What kind of ECU are you running? We have individual cylinder fuel control on the cars we tune with AEM so by monitoring EGTs we can adjust accordingly.
How are you monitoring knock noise? Timing, heat range of the spark plug and octane??
Old Jul 13, 2006 | 02:02 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How much timing advance?
Old Jul 13, 2006 | 02:23 PM
stssilverado's Avatar
using stock PCM tuned with HPTuners by Nelson Performance
Old Jul 13, 2006 | 02:32 PM
1936FordPU's Avatar
Originally Posted by trtturbo
Back to the top for you Brandon. I would be interested in others opinions too.
Your breaking ring lands from that picture.
Cylinder pressure breaks them. Whats your rings gapped at and what style rings are they?
Old Jul 13, 2006 | 02:51 PM
LSONE's Avatar
i've read that depending on your fuel setup, you could be seeing less psi at the back of the fuel rails, and therefore would be running leaner.
Old Jul 13, 2006 | 04:19 PM
nitrorocket's Avatar
It is your afr plain and simple. Even a short spike to 12.5:1 can break something at 12 psi. You have to tune yourself, you cannot do a mail order tune and have it correct with a turbo car.
Old Jul 13, 2006 | 08:38 PM
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by stssilverado
who is Jose?
Pretty much the guy who know everything about turbos and turbo engines and setups. Its worth giving him a call and chatting. May give you some ideas.
Old Jul 13, 2006 | 09:16 PM
is jose a screen name? or am i supposed to know him already?
Old Jul 13, 2006 | 09:41 PM
Boostaholic's Avatar
His username is JZ 97 SS 1500
and I'm also curious to know what kind of WOT timing there was in this tune?
I think my car runs 17deg@9psi
Old Jul 13, 2006 | 10:06 PM
I am at 18 degrees timing with 11.3:1 AFR @ 16 psi. I keep the 18 through the entire boost range although I could raise it at lower points for more power. 11.3:1 AFR is very solid on a pumpgas tune.
Good luck!
