ATI D1SC or P1SC
Old Jul 13, 2006 | 09:29 PM
99LS1Z28's Avatar
Default ATI D1SC or P1SC
I have been thinking about getting a procharger but i am not sure which one to get. i dont want to run too much boost because the internals of the engine are stock and i want to still have a reliable car. the mods in my sig are the only mods i have and after the procharger i will most likely be done modding the car. So i was wondering how much boost i should run and which procharger to get. Thanks
Old Jul 13, 2006 | 09:39 PM
BIG BAD BLACKSS's Avatar
Get a D1, you can change pullies and the blower will be able to keep up with your needs for much longer t hen a P1. You will kick yourself in the *** later down the road as you want to make more power.
Heck i have a D1 and im kicking myself for not getting an F1C!
Old Jul 13, 2006 | 09:43 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
+1 4 D D1.
Old Jul 13, 2006 | 10:24 PM
blue2002ss06's Avatar
D1sc period end of story
Old Jul 13, 2006 | 11:22 PM
02ws6blackbird's Avatar
like everyone else said the d1 is the way to go i am putting mine in now. it will keep up with what ever you want to do down the road and it has bigger twin high flows thats more power their
Old Jul 14, 2006 | 05:25 AM
EPP's Avatar
EPP
The price difference between the P-1SC and the D-1SC head unit is only several hundred dollars. Both blowers use the same housing, but the D-1SC is capable of producing more boost in case you decide to upgrade the engines internals in the future. You can send in a P-1SC to have it upgraded into a D-1SC, but it will cost you $1,200.00.
The D-1SC F Body kit comes with one inch thicker intercoolers than the P-1SC kit does, on the 98-up F Body, plus it comes with the eight rib belt assembly. I always recommend the D-1SC kit. More is better in this case... Bob
Old Jul 14, 2006 | 05:56 PM
99LS1Z28's Avatar
So if i run like 7 psi would i need to upgrade any internals on my car. b/c i am really trying to steer away from that. I want to keep the motor as stock as possible so it is still good and reliable.
Old Jul 14, 2006 | 06:02 PM
caindo's Avatar
i run 7.5 psi, 05 gto. stock motor (+cam). you'll love it.
Old Jul 14, 2006 | 06:15 PM
99LS1Z28's Avatar
i was also looking at an sts turbo b/c it is cheaper and not always in boost so i wont really loose gas mileage to much. i dont know too much on them but do they sound bad b/c i read that they relplace the muffler on the car. or is a procharger a better route. thanks
Old Jul 14, 2006 | 08:11 PM
todd4168's Avatar
Go with the procharger or vortech , Id stay away from sts. Im sure most on here will agree.
Old Jul 14, 2006 | 09:23 PM
Procharger is not in boost either, that is until you go WOT.
Old Jul 14, 2006 | 10:15 PM
BudH's Avatar
D1, D1, D1, D1, D1
Get the idea!
Old Jul 14, 2006 | 10:28 PM
Slowhawk's Avatar
LS1Tech Sponsor
Alot of people go D1 but there really is no reason too on a stock motor Car.Sometimes we run the P1-2 which easilly makes 500rwhp on a stock motor or 600rwhp on a stock motor with headers and a small Cam (10lbs of boost).Just when you order the P1 setup you go for the 8rib and upgraded intercoolers.
Old Jul 14, 2006 | 10:43 PM
fastlt1's Avatar
I thought the LT1 came with the 8 rib belt and the LS1 had the bigger intercoolers.
Old Jul 14, 2006 | 11:10 PM
8 rib is optional on both LS1 kits. The LS1 kits both got the upgraded cooler though im pretty sure.
Old Jul 15, 2006 | 01:38 AM
Z2K_MrJ's Avatar
Board Certified Idiot
Your only going to be running about 6 psi..The New Procharger systems are Preety nice
Old Jul 15, 2006 | 05:14 AM
EPP's Avatar
EPP
Question
The LT1 has the eight rib belt width as standard on the base kits. The twin high flow intercoolers kits come with a wider 12 rib belt. The larger 4.5" intercoolers cannot be ordered with the LT1, only the 3.5". Bob
Old Jul 15, 2006 | 05:16 AM
EPP's Avatar
EPP
Smile
The D-1SC kit automatically comes with the eight rib blower belt. The P-1SC comes with the 3.5" intercoolers as standard. The D-1SC comes with the larger 4.5" intercoolers as standard. Bob
Old Jul 15, 2006 | 05:20 AM
EPP's Avatar
EPP
Thumbs up
The ProChargers are only in boost under wide open throttle. Under part throttle conditions the boost is being relieved through the by-pass valve.
Gas mileage under normal driving conditions with an ATI ProCharger is still about the same as it was before the blower installation. Bob
Old Jul 15, 2006 | 05:22 AM
EPP's Avatar
EPP
Smile
No, with a good tune the engine will last a long and happy life. My own '99 Z28 had 110,000 miles on the engine when we added a D-1SC to it. It ran great all the way up to 125,000 miles, at which time we bumped the boost up to 15 psi to see how long it would survive. It lasted a lot longer than we thought it would. Bob
