ls6 valley cover?
Old Jul 14, 2006 | 09:42 PM
SVC707's Avatar
Default ls6 valley cover?
i just got my katech valve covers and dont want to drill a hole to run the pcv on the driver side. it is predrilled for the passenger side though. my question is, i know i need to run some kind of pcv setup since i will be running the procharger. is the ls6 valley cover something i SHOULD be doing, seeing how having just the passenger side tapped probably is not enough to release pressure. its only $50 something plus shipping brand new.
oh yeah and does the ls6 valley cover go right onto the 408 iron block, i dint bother to check before i put the ls1 cover on it.
Old Jul 14, 2006 | 10:27 PM
Boostaholic's Avatar
just make sure your intake manifold will clear it, they used a different manifold on thoes cars with valley pcv. Its a much cleaner looking setup though
Old Jul 14, 2006 | 10:34 PM
MiaSSmaro98's Avatar
yeah i will like to know if u can run a stock pcv/breathing system on a F/I engine because i also see people putting breathers and one way pcv vavles so wats the deal?
Old Jul 14, 2006 | 10:38 PM
SVC707's Avatar
what do you mean, they? who/what are you referring to?
Old Jul 15, 2006 | 08:47 AM
Navy David SS's Avatar
SVC707. #1 you have a 2002. Therefore you have an LS6 intake already. Therefore you have the LS6 valley cover. This is what I have done (I use to have an LS6 intake/valley cover, now a Victor Jr). I assume you are going to be running the stock LS6 intake - right? Use a rubber tubing from the PCV pipe from the valley cover to a catch can, I use a breather on top of the catch can. I also use a breather for the valve cover. Works great for me. What little blow by from the either breather is very very minimumal. I have had no oil to catch can yet.
David
Old Jul 15, 2006 | 09:01 AM
SVC707's Avatar
i dint have a ls6 valley cover....? i dont have my factory ls6 any longer. im looking into other intakes already. but i know i wont be able to fit the victor jr without cutting the cowl correct
Old Jul 15, 2006 | 09:02 AM
david when on boost do u have to do all this pcv/breathing mods?i wanna know
Old Jul 15, 2006 | 09:05 AM
SVC707's Avatar
this is what came off my 2002 ws6.. ls1 valley cover
Old Jul 15, 2006 | 10:37 AM
Country Boy's Avatar
Senior Member
The F car never got the LS6 valley covers. Just the LS6 intakes.
Old Jul 15, 2006 | 12:42 PM
SVC707's Avatar
I think im better off just ordering it anyways....
Old Jul 15, 2006 | 12:44 PM
Or since you already have the ls6 intake you could just get a 90deg fitting and drill/tap your current cover, should be fine and cost just a few dollars
Old Jul 15, 2006 | 01:25 PM
SVC707's Avatar
yeah i should do that too. ive got the FAST90 setup from when i was running the bottle but ive been thinking about doing something different again.
Old Jul 15, 2006 | 01:27 PM
u can actually do that it wont hit the manifold?
Old Jul 15, 2006 | 11:01 PM
Last year - on nitrous and now on boost - I used the same set up. Catch from valley cover; breather on valve covers. We have dyno the SS on 17lbs of boost (only 8 at the track) without any problems. I can't say that you or someone else may or may not. I only know what works for me.
David
Old Jul 16, 2006 | 04:59 PM
SVC707's Avatar
david, what size were those plugs used to plug the ports on your water pump that were for the heater core. i want to plug mine too
Old Jul 16, 2006 | 05:26 PM
No idea right off hand, did that 3 years ago. Would have to go to the shop tomorrow. Maybe someone has their car at home??
David
Old Jul 16, 2006 | 05:47 PM
SVC707's Avatar
i dont know the thread pitch just thought id take a short cut and ask you since i saw it on your page. reminded me to get rid of the wrap around hose
