LT1 vs LS1
Old Jul 20, 2006 | 04:32 PM
Ari G's Avatar
Default LT1 vs LS1
Is there any benefit of turbocharging LT1 over LS1?
Like Is the reverse cooling better on LT1 for detonation?
Old Jul 20, 2006 | 05:27 PM
Boostaholic's Avatar
No, there isn't.
The LT1s are actually harder to work on, here are a few of my gripes with the LT1
Oil pan is a bitch to mess around with, also the timing chain cover which involves lowering the oil pan.
Intake manifold and valley cover are one piece
Distance between exhaust ports isn't equal, made it a little harder to make LT1 headers.
LT1 oval throttle body required us to get a oval to round elbo piece
Harder to setup aftermarket engine managment, requires pickup wheel and possibly more modifications, for BigStuff3 anyway.
Good things about the lt1
You can get the lifters out without pulling the heads
I like the oil pump a lot better
Pretty much all parts are cheaper, we built a forged LT1 for a fraction of what my forged LS1 cost.
Old Jul 20, 2006 | 06:02 PM
engineermike's Avatar
Well. . . you'll get both sides on this one. . .
The LT1 has 5 bolts per cylinder, plus they have iron blocks. Big Rick ran 8.0's on a production LT1 block and I don't think anyone has gone that fast on an LS1 block.
The LT1 stock ECM is easier to mess with. For <$200 you can do all the custom programming you want.
Another LT1 advantage is that you can fit a turbo without moving the stock cooling fans, getting rid of any accessories, or running pipes under the k-member.
Round to oval adapters are $75 and readily available.
Mike
Old Jul 20, 2006 | 06:06 PM
frcefed98's Avatar
Mike, can you send me some info on what you use to tune an LT1. I'm currently knee deep in a 396ci LT1 turbo build and I'll need some tuning software very soon.
....we had to loose the stock radiator and fans on this LT1 turbo build
J
The LT1 has 5 bolts per cylinder, plus most are iron blocks. Big Rick ran 8.0's on a production LT1 block and I don't think anyone has gone that fast on an LS1 block.
Mike
Yep thats definantly true, our LT1 kit puts the turbo on the drivers side where the AIR pump went and fits great without relocating anything at all. LS1s use this location for alternator and ps pump
Old Jul 20, 2006 | 06:08 PM
I just use TunerCAT.
Old Jul 20, 2006 | 06:10 PM
frcefed98's Avatar
Cool, i'll look it up, never messed with the LT1 tuning stuff so i'm in the dark at whats available for em.
J
Old Jul 20, 2006 | 06:16 PM
qqwqeqwrqwqtq's Avatar
Yeah, the LS1 is much more advanced/efficient regardless of application. I think it's only disadvantage is 4 head bolts per cylinder.
That, and it was much easier to fit twins down low on my LT1.
As far as tuning, the LS1 computer with 2/3 bar operating system is awesome. IMHO the stock LT1 computer sucks for a boosted application, SD is the only way to fly.
Old Jul 20, 2006 | 07:02 PM
I've been looking at this more recently. Why can't you do just as good with an LT1 ecm and 2 or 3 bar SD tune? If you unplug the MAF, it goes into SD mode and the 93's came stock like that.
Just curious. . .
My initial impression from Alvin at PCMForLess is, "don't even try it". Hmmm. . .
Mike
Old Jul 20, 2006 | 10:00 PM
frcefed98's Avatar
Yeah my 93 Z28 A4 was SD, no maf at all. Most I ever did to that was N2O tho.
J
Old Jul 22, 2006 | 01:12 AM
whynot's Avatar
93's are chipped though, not eprom, so you would have to have a chip burner, or some other way to get around that.
Old Jul 22, 2006 | 06:17 AM
I've been told that simply unplugging the MAF will make the '95 ECM work just like the '93. I know for a fact that I can unplug my MAF and it drives just fine.
Mike
Old Jul 22, 2006 | 02:39 PM
whynot's Avatar
so what all is tuneable on a lt1 ecm?, can you program in a 2 or 3 bar?
because this might be something for me to look into, because I am having a hard time finding anyone willing to burn me a chip.
Old Jul 22, 2006 | 02:44 PM
burnzilla's Avatar
ODB1 sucks big donkey *****. I had to drive 3 hours to Albany to find a shop who had PCMforless.
It was either that or mail order, and I dont have a Laptop or the adapter plug.
Ohhhh, and very cool name for a thread. I have a feeling its gonna get hot in here.
I thought all LT1's in Fbody's where Cast Iron?
Mike
Yeah, just gotta find someone who can tune it first.
Old Jul 22, 2006 | 03:00 PM
GrahamHill's Avatar
Ive got a block yall can have with several cracks at the cylinders from that fifth bolt hole the LT1's have lol
Old Jul 22, 2006 | 08:09 PM
Ari G's Avatar
93 lt1 are SD and have a chip,eeprom.The programming is not so hard if you get into it,TunerCat and TurnerPRO RT are good programs
Alvin at PCMforless is very good
Old Jul 22, 2006 | 08:13 PM
not really, pcmforless won't touch boosted cars
Old Jul 22, 2006 | 11:41 PM
whynot's Avatar
at least not mine! long story made short, I pissed him off.
He said the only way he would tune mine is in person, on a dyno, so I told him at that price, I might as well get an aftermarket stand alone and tune it my self! (somewhat hopeing he would be willing to help out)
Old Jul 23, 2006 | 01:22 AM
KyleW93z's Avatar
Alvin set me up with a base tune for my 93. He did the 2 bar conversion, bigger injectors and more displacement, needless to say its not going to smoothest but that is not his fault. I dont think that ill have a lot to do to the tune once i get everything running properly.
Old Jul 23, 2006 | 03:12 PM
whynot's Avatar
Yea, I tried to get him to give me a tune for 75 lbhr injectors, a good sized cam, and a 3 bar, but he would have none of it.
