FI + Injector question
Old Jul 20, 2006 | 06:13 PM
67Firebird455's Avatar
Default FI + Injector question
I just realized the FMS green-top 42lb injectors I have (currently) are rated 42lbs @ 40psi fuel pressure. If I'm running 58# fuel pressure, what do these actually flow? I need a set of Mototrons, but want to break the new motor in with the 42's and low boost before jumping to 15 or 16# on a tune. Any place to calculate flow at specific fuel pressures?
Old Jul 20, 2006 | 06:24 PM
SSmokin 01's Avatar
http://www.csgnetwork.com/fiflowcalc.html
Old Jul 20, 2006 | 06:34 PM
bowtieman81's Avatar
check in the tuning section for the SVO injector thread. You can calculate the flow rates with Marcin's sheet. FWIW, the 42 SVO injectors (which is what I run too) are actually about 48lb at our fuel pressure.
Old Jul 20, 2006 | 06:39 PM
Wow, that's great... Thank you, both of you! I have also heard the mototron 60's are actually 65? At what pressure are they referring to? At our pressure, what is the true flow?
Old Jul 20, 2006 | 10:08 PM
Not sure on that one, not familiar with the 60 lbers.
Old Jul 21, 2006 | 08:10 AM
shiftinda93z's Avatar
When I installed the FMS 42's, we had to actually enter them as flowing 42, not 48.
Old Jul 21, 2006 | 08:17 AM
Old Geezer's Avatar
Original flow rating X the sq root of the new PSI, divided by the old PSI.....
IE: 42 x SQ rt of 60
---- = 42x 1.1952 = 50.19PPH
43
