Turbo whine.......question
Old Jul 20, 2006 | 06:28 PM
tomulrich's Avatar
Default Turbo whine.......question
I just set up a 427ci twin turbo 67mm. Why is it that I cannot here the turbos whining?
I have even had the rpms to 4000...no whine........not even reading boost on my Eboost2
Please help
Tom Ulrich
Old Jul 20, 2006 | 06:31 PM
Ryan K's Avatar
Pathological Modifier
Are you just reving the engine or actually putting it under load? Just reving it up with no load, you're not gonna hear the turbos spinning up, but you should be able to feel air come out of the BOVs.
Ryan
Old Jul 20, 2006 | 06:33 PM
qqwqeqwrqwqtq's Avatar
Well the layout of the setup and the specs on the exhaust and all other components (and driving condition) have influence on how pronounced turbo noise will be.
Was the 4000 rpm under load? You may allready know this but you could be at a sustained 7000rpm and the turbos will build no boost unless the engine is under a load.
Boostaholic's Avatar
Ryan
Thats not really true, I could tap the gas at idle and hear the whistle from my Twin T70s and 60s
But I would guess that under load they will make a lot more noise, it also helps if you have full exhaust on the car instead of open DPs
Old Jul 20, 2006 | 07:22 PM
bboyferal's Avatar
I don't build boost, but I certainly hear the turbo make some sweet spool sounds out the exhaust when I rev while stopped.
Old Jul 20, 2006 | 08:21 PM
sr71's Avatar
you can hear mine at idle and you can really hear them going down the road. but, I have no muffs. muffs kill 95% of the turbine sound. some hear the compressor whine, but mine is all turbine.
Old Jul 20, 2006 | 08:36 PM
Ryan K's Avatar
I can't hear mine at all without a load. However under load : ITS LOUD!
Ryan K.
Old Jul 20, 2006 | 08:53 PM
mahhddgtp's Avatar
You can actually hear the turbo spooled once you floor it... This is totally unlike some Supra dyno videos I've seen lately..... You can hear it spool at like 6000rpm
Old Jul 21, 2006 | 11:08 AM
bboyferal's Avatar
Very true... I run a Loudmouth, so that's almost like no mufflers... It's cool to hear them out the back and not have to floor your car.
Old Jul 21, 2006 | 11:19 AM
sr71's Avatar
my 3" pipes run through the frame of my vette and turn out through the rocker panels in front of the rear wheels like old school sidepipes. you can really hear mine especially on the freeway with a concrete barrier beside the car. it kinda sounds like a 747 passing by.
Old Jul 21, 2006 | 11:27 AM
bboyferal's Avatar
I know exactly what you're talking about when turbo whine comes out the exhaust and reflects off of walls... But you have sidepipes facing the walls? Holy S*** that must sound AWESOME.
Old Jul 21, 2006 | 03:39 PM
MiaSSmaro98's Avatar
damn cant wait for my whine should come by the end of the year
Old Jul 21, 2006 | 07:09 PM
gEtyOPaPiOn's Avatar
well i have a 346 with twin 60s and 3 inch exhaust all the way out with borlas and barely any noise with no load ...havent taken it out to the streets yet
Old Jul 22, 2006 | 01:31 PM
PurEvl's Avatar
mine makes hardly any noise unless im on the throttle and the cutout isopen....plus my wastegate is vented to the ground so thats all you really here.
Old Aug 14, 2006 | 07:33 PM
MyWs62FaST4u's Avatar
Lol, What About Resurrecting A Thread, And Suggesting Open Downpipes
Old Aug 14, 2006 | 10:50 PM
Mike 01WS6's Avatar
I run one as well. It's nice to have the top down and hear the turbo whistle come over the deck of the trunk.
Now when the cutouts are open (pointed out to the sides), you can really hear the whistle!
Old Aug 14, 2006 | 11:34 PM
TransAm6383's Avatar
I cant wait for mine to be done..this is gonna be sick...
