procharger drain bolt leak!
Old Jul 20, 2006 | 10:28 PM
C.W.A's Avatar
Default procharger drain bolt leak!
I have a D1SC that likes to leak oil from the drain bolt! The shop took the superchager off to make sure the bolt was on tight ,but I still have a slow leak around the same bolt! help
What do I do? tape,locktight!
Old Jul 21, 2006 | 04:37 AM
DJ's Z's Avatar
I would try this first...Make sure the rubber seal is still on the bolt...check it to make sure its not ripped or worn. You may want to replace it anyway just to be sure. Any good auto/hardware should have an assortment of seals. Bring the bolt and get the correct size...
Old Jul 21, 2006 | 05:08 AM
EPP's Avatar
EPP
Thumbs up
I agree, good idea. Bob
Old Jul 21, 2006 | 04:16 PM
C.W.A's Avatar
thanks guys, the rubber seal is in good shape! any other ideas?
Old Jul 21, 2006 | 08:33 PM
Bad30th's Avatar
Try a little teflon tape around the bolt ?
Rob (Bad30th)
Old Jul 21, 2006 | 09:29 PM
peppersac's Avatar
J.B Weld. Just kidding!
Old Jul 22, 2006 | 09:17 AM
C.W.A's Avatar
I like that idea, just lock that bitch up!
Old Jul 22, 2006 | 09:45 AM
topfig1's Avatar
I would replace the seal any way. With heat and time the seal takes the shape that it is in when crushed by tightening the bolt but it still looks normal. I would also put teflon tape on the threads as suggested above.
Fig
