just installed procharger...help!
Old Jul 22, 2006 | 09:26 PM
68ss_00ss_87_95's Avatar
when its idling rev it to like 4k real quick then let it drop and listen for the surge valve...you can hear it cycle...if it doesnt make the little flapping sound then ur line to the valve is messed up...make sure your line isnt pinched either....i had the same problem so we swapped it over to the controller on the driver side, i think its the brake booster, whatever the damn round this is at your firewall!...hook it up there if your not getting good response, normally i get 20 inches maybe 24 at idle and if i rev it it goes to 0 maybe 1 but on the road it goes up to about half boost then climbs as you accelerate.....ill see if i can get a pic of where my line is setup so you can reference that and work with it from there...
Old Jul 23, 2006 | 03:34 AM
ss02camaro35th's Avatar
Originally Posted by 618HAWK
Did you try driving it with the bypass valve vacuum line disconnected?
You say the crank pulley bolt is tight, are there dowel pins in the procharger pulley to keep it from spinning while in position in the crank pulley? Seem to remember some issues in the past, of either no dowel pins or the crank bolt being just s bit to long.
How is the intake side of the blower, any blockage, or problems there.
no i havent tried that yet, i will do that tommorow but as far as the crank goes it does have dowel pins in the pulley and i dont see anything that would be restricting the airflow into the charger. i guess ill be calling procharger monday see what they say...
Old Jul 23, 2006 | 08:16 AM
Slowhawk's Avatar
LS1Tech Sponsor
Is this a stock car? I did a Cammed car recently and with the 8lb basic kit the car only made 2lbs of boost,but it made 540rwhp.
Old Jul 23, 2006 | 10:28 PM
no it is stock
Old Jul 24, 2006 | 05:24 AM
EPP's Avatar
EPP
Question
Very true, we typically cut .38" of an inch off the supplied crank bolt on the six rib ProChargers to make sure they do not bottom off. You also want to use red loctite on the crank bolt, as they have a tendency to work loose.
It also sounds to me that your bypass valve is not working correctly. I recently had one that would not close far enough. We swapped it out with another ProCharger bypass valve and it immediately picked up two pounds of boost. I would first disconnect the vacuum line, as the line is normally hooked up wrong when this problem exists. If you still do not see much boost, I would then try running the car briefly without the valve installed, to see if it is the culprit.
Let all of us know what you find out. Bob
Old Jul 24, 2006 | 12:37 PM
redline.inc's Avatar
To get rid of the rattle at idle, i think you should invest in the SD Concepts pulley kit. The rattle goes away and the belt wraps around the pulley even more and also, no slipping. I installed it on mine, and it is a night and day difference. good luck with getting it running right.
Old Jul 24, 2006 | 03:23 PM
where do i get that at?
Old Jul 24, 2006 | 10:02 PM
618HAWK's Avatar
http://www.sd-concepts.com/cart/inde...products_id=19
So any update on your problem?
 Michael S. Palmer
Old Jul 25, 2006 | 12:07 AM
not yet, i am gonna try tapping into a different vacuum source like the booster hose for the bypass valve and boost gauge...i took the main tubes off while it was idling and disconnected the bypass valve and it was flowin a lot of air even at idle not to mention revving it, so im hoping a different vacuum source will do it ahh well, if thats the amount of power 5 psi gets me im gonna have to get a 7psi setup and get the 8 rib setup from sdce cause the rattlin is makin me nuts too
Old Jul 25, 2006 | 08:34 AM
WAHUSKER's Avatar
A loose belt & loose clamps are the first place to look, tho that only limited my boost to around 4 psi. Have you monitored the boost gauge as your RPMs climb? Does it go to 1 psi at 3k & stay there? Or does it climb up & then drop back down when you hit 5500? (floating valves or running out of fuel)
Is this a new or used system? What are your pulley sizes? Re-torque their bolts (don't just look). Is your dipstick blowing out? Do you have a metal intake plenum? Have you checked it for cracks, or the inner coolers? Throwing any codes? What is your a/f?
Sorry, but there are many things you need to check.
Old Jul 25, 2006 | 06:12 PM
extremez97's Avatar
dumb question-did you put the oil in the unit?
Old Jul 27, 2006 | 04:07 PM
  #32
yea...all 6 of the hard as hell to put in ounces
