Remotemount wastegate vacuum line placement
I'm looking for the Pro/Con of running my vacuum signal from the rear mount wastegate back up to just before the throttle body???i'm thinking it would get a more accurate boost reading...any input appreciated.thx,mike.
Originally Posted by trtturbo
If you have an intercooler, you need to get your reference from the intake.
Lets say your wastegate spring is .4 bar which is about 5.5psi. If you use an intercooler, there will be pressure drop, so if your reference is at the compressor housing, then the intake will not see the full 5.5psi. If the reference is at the intake, then that is what the wastegate sees and runs what it should according to the spring.
Like TRT said, if the reference is at the turbo you will have to run a bigger spring / more pressure to the gate to make the same amount of boost at the intake because of the pressure difference between the turbo inlet and the throttle body
I had an issue with this. If you have an intercooler you have to run it to the intake like trt said. I think then if you have a BOV you have to run that one to the back.
Originally Posted by MiaSSmaro98
so u want the wastegate and bov connect to the air filter side on the turbo?
You want your bov reference line to a good (brake booster) vacume source.
Originally Posted by hpcubed
According to Tial, the wastegate reference should be before the throttle body. Any reason why they don't want the gate to see vacuum?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
