I'm posting this helping my neighbor out, guy has been through several shifters and still the same problem.
I have been all over the internet myself and have seen this is a very common thing with running a shifter mounted in the forward positon on the Tailshaft. The Reverse Gear slings fluid literally up the Shifter because the Shaft is located directly above it.
My thought is a deflector shield above the Reverse Gear below the Shift Rail part where the Shifter goes into. Has anyone seen anything like that out there before I fab up something on my own. Seems like a pretty major design fail on Tremec, but then again that's your typical engineers that see it on a computer and don't know how **** in real life works.
Do you have a standard magnum, magnum xl, or a magnum f trans?
The shroud is for the standard magnum with a 6 bolt shifter base. In this pic the shifter is in the rear position. It can be flipped to put the shifter forward 3” or so.
The 6 bolt regular T56 Magnum cast shifter is known for leaking.... so you need to replace it with another brand.
The T56 magnum F 4 bolt unit is not known to leak... clean the area with brake cleaner and diagnose where it is leaking from.
That exact thing is in the car right now and it's absolutely worthless, so people make note of that.
Exactly that, just in the forward position because of the car it's in, In my very first post I mentioned what I think the exact cause is.
Fluid comes up through the Shifter, literally up through it, no diagnosis needed. So far 4 different shifters in the car and same problems out of all 4.
Line of sight is looking straight down through the Isolator Bushing and seeing the Reverse Gear.
I'm going to do you a favor and quote my original post, it seems you haven't read it.
I'll stand behind the above, and maybe what we end up doing to try it. I have the ability and resources to fab something like that up.
