Head Gasket leaks
Old Aug 5, 2006 | 03:54 PM
02SSLE's Avatar
Default Head Gasket leaks
I was just wondering when I tour my motor down I noticed that there was suit bleeding out of the head gaskets on my car. I was wondering how much boost you can run with head studs before you need to O ring the block? Also what do you guys think is going on there? Do you think I am lifting the heads a little? Or something else?
Old Aug 5, 2006 | 09:09 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Soot?
Old Aug 5, 2006 | 09:41 PM
02SSLE's Avatar
yes sorry
Old Aug 6, 2006 | 02:47 AM
JMBLOWNWS6's Avatar
I was running 11 psi and when the rod bearing spun and I took it apart there wasnt any seepage. ARP head stud TQed to 75 w/arp moly lube. 6.0L MLS head gaskets cooper coated
Old Aug 6, 2006 | 07:01 AM
SINISTER's Avatar
i do belive Harlen was well into high horspower and 8 sec with the lovely mls gaskets studs and no o rings
Old Aug 6, 2006 | 07:53 AM
Slowhawk's Avatar
LS1Tech Sponsor
We've run 20lbs of boost so far without head gasket failure.It comes down to the tune,Too much timing/wrong fuel will lift a head.
Old Aug 6, 2006 | 11:46 AM
02SSLE's Avatar
So you all think the head may of not been torque properly?
Old Aug 6, 2006 | 12:12 PM
nitrorocket's Avatar
Something was wrong with either the torquing or the deck and or head surface. That is not that much power for those gaskets, you should not have a problem.
Old Aug 6, 2006 | 03:43 PM
LS1Tech Co-Founder
Do you mean the head gasket had some spots where it had blown out or the whole gasket had lifted?
Old Aug 6, 2006 | 05:10 PM
02SSLE's Avatar
gaskets looked fine. just soot bleeding out on the under side and top side out of block.
