turbo cam? is this too much
Old Aug 14, 2006 | 11:35 PM
cjg454ss's Avatar
Default turbo cam? is this too much
comp cam 236/242 .598/.610 114+4, going to run stock 346 cubes forged pistons, rods. ect with a t70 turbo 12-14 lbs of boost, car is an auto 02 ss 3400 converter. i have the cam and was going to sell it but was wondering if it may still work.
Old Aug 15, 2006 | 03:30 AM
red90cobra's Avatar
it'll work
Old Aug 15, 2006 | 08:43 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
That's more than I will be running with my GT 47-88 turbo.
Old Aug 15, 2006 | 08:52 AM
bowtieman81's Avatar
Almost any cam will WORK with a turbo, but will it work well and produce what the owner wants. It is the same deal with n/a cams, many will work but you should choose based on what you want to do with the car and what you want out of it.
Old Aug 15, 2006 | 10:13 AM
~JOSHUA's Avatar
That cam is a bit big.
My 236/236 was left in because I didn't feel like swapping cams in addition to the turbo install.
I can already tell that I'm probably going to switch to a smaller cam in the future. Probably in the 220-224 range.
Old Aug 15, 2006 | 10:29 AM
SuperZ's Avatar
well it Will WORK but I wouldnt do that big of a cam.Im running a 220/224 551/551 114 in mine and love it.At most Id go high220s durations
Old Aug 15, 2006 | 01:40 PM
LS1Tech Co-Founder
cjg, you can always try it and see what happens. The cam you mentioned is what I ran with the blower setup. I made 754rwhp at 6600 with 21 psi but I'm not sure how the turbo will peak.
Old Aug 15, 2006 | 01:45 PM
y2khawk's Avatar
my old cam was ~250/250 .6xx lift 114lsa
new cam is 26x/26x .7xx+ lift 115lsa
don't let anyone tell you it's too big, especially PSJ
It's all about where you want the power in the RPM band
I might rethink the turbo choice though, you'll be hard pressed to get 14 psi out of a 70mm unit and make decent power with the air it does move at that point. My .02 anyway
Old Aug 15, 2006 | 02:05 PM
LS1Tech Co-Founder
Shifted at 7800?
Hi Matt!
Old Aug 15, 2006 | 04:04 PM
y2khawk's Avatar
car done yet john??
Old Aug 15, 2006 | 04:51 PM
LS1Tech Co-Founder
In progress.
How about Kevin's Formy?
