GT47-88 Build pictures (1998 Formula) ---->
Old 09-19-2006, 04:50 PM
  #161
FASTEST ALL MOTOR LS1 IN THE COUNTRY
CAMN HAWK's Avatar
good luck john everything looks great.
Old 09-19-2006, 05:06 PM
  #162
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
Thanks, I tried swinging by your new restaurant but did not know the address.
Old 09-19-2006, 08:43 PM
  #163
TwnTrboCE's Avatar
I think you'll need to spin it higher to get everything out of it. I spin my LS2 to 7500. Will find out this weekend what the new motor likes. What lifters you running?
Get that thing to the track ASAP.
-Plan to rev to 7000 at this point
-No I don't think a 3.27 stroke would have helped at all, I'm even thinking the opposite for the next shortblock. I'm considering a 8.0:1 370-402ci setup. Over the years I have not seen any evidence to say that piston velocity and side loading etc. warrant us keeping the stroke down. But I'm undecided at this point.
-Rev springs, 1.7 non-adjustable Y/T rockers, Inconel exhaust valves that can take more heat..... 2.05/1.60 valve sizes
-900rwhp is possible not sure I want to turn it up that high without first making some runs. I'd like to end the year on a good note not broken.
Old 09-20-2006, 07:56 AM
  #164
smokinHawk's Avatar
still hydraulic?
what does your valvetrain consist of?
you still have a stock tach, how where you shifting the rossler 210? (that was a rmvb right?) your 4l80e was shifted by the bs3 computer right
Old 09-20-2006, 09:13 AM
  #165
LS1Tech Co-Founder
Comp OE style replacement lifters.
I used to spin the blower combo to 7100-7200.
I've got the spring pressure to run it up higher, that's always an option.
Old 09-20-2006, 09:53 AM
  #166
2001-WS6's Avatar
...Get that thing to the track ASAP.
Come on... you know the PSJ process by now... there are many many dyno sheets to come before we can see it at the track.
It was like an Alley Oop play... I had to finish off the dunk.
Rick
Old 09-20-2006, 10:00 AM
  #167
TwnTrboCE's Avatar
Originally Posted by smokinHawk
still hydraulic?
Yep, hydraulic in both motors.
LS2- Comp-R lifters, Harland Sharp rockers, Comp dual springs
ERL- Morel lifters, T&D Shaftmounts, and Gold dual springs from TEA.
Still have the stock tach but use a shift light when I run the TH210. BS3 does shift and lockup the 80E.
Back on track. PSJ, from what we have been told the stock style replacement ones from Comp aren't designed for high RPM or really high seat pressure. That combined with high boost could be very bad. I started out with a new set of Comp-R's in the ERL block and they gave me nothing but problems. From the looks of them just after the short time I ran them. I wasn't happy. The cup retainer was distorted and looked like it could possibly pop out. We won't run any Comp lifters again.
Old 09-20-2006, 10:19 AM
  #168
2001-WS6's Avatar
Yes, the Morel lifters do appear to hold up to a beating and have been fine on the track and the street for over 5K miles of abuse.
Rick
Old 09-20-2006, 11:15 AM
  #169
LS1Tech Co-Founder
I have run Comp lifters since 2001 not to the power levels and rpms you have been running. I had a set of Comp R lifters in my old stroker. Either way we'll see.
Quick Reply: GT47-88 Build pictures (1998 Formula) ---->
