cam?
Old Aug 17, 2006 | 06:52 PM
1999 SS's Avatar
Default cam?
i keap going back and forth between the idea of going FI or spray. i just recently upgraded to a Futral f14 cam(232/234 112lsa) and know that the cam wont be an issue for spray but should it cause me any conserne if i were to SC or turbo the car?
Old Aug 17, 2006 | 10:00 PM
Sixspeed042's Avatar
definately FI it. have bret bauer make you a cam
Old Aug 18, 2006 | 01:23 PM
SSblack98's Avatar
It would probably be ok for a SC but too much overlap to work efficiently with a turbo setup.
Old Aug 18, 2006 | 04:32 PM
SSilverSSurfer's Avatar
werd you'll bleed off some boost, sell it and get a new one, like the LPE GT2-3
Old Aug 18, 2006 | 05:13 PM
1999 SS's Avatar
i dont want to replace this cam i just installed it a couple hundred miles ago.
if it has to much overlap could i just run a little higher boost to possible replace whatever is blown out the exauhst valve before it closes?
why would it be ok to supercharge it and not turbo?
Old Aug 18, 2006 | 05:27 PM
ninetres's Avatar
Are you on a stock bottom end? It might be some nice insurace to bleed a little boost. Many well seasoned LS1 turbo folks have told me that exact cam specs aren't really a HUGE deal unless you are bracket or competitivly racing. You might see a few more ponies from the ideal cam....or spool a couple hundred RPMS sooner....but for a turbo street car, any cammed car will go afster with a turbo.
