tuning..........turbos
Old Aug 18, 2006 | 05:05 PM
KAOS's Avatar
Default tuning..........turbos
gotta question. once i get my car tuned in how much after that do i have to mess with the tuning? like with a NA car you tune it and its done, right? so once you tune an fi car is it done?
also how much power can you get with a stock computor/ stock map sensor. i mean is 700 rwhp out of the question for a stock setup?
trying to debate if its worth my time or not to keep the car i would really like to sell it but im having second thoughts. any opinions would be great.
Old Aug 18, 2006 | 05:12 PM
bboyferal's Avatar
The stock pcm has gotten Nitrorocket 1k crank estimated bhp on 93 octane (no meth).
The map sensor's got to go though.
Old Aug 18, 2006 | 05:35 PM
Country Boy's Avatar
Senior Member
why a stock MAP sensor?
Old Aug 18, 2006 | 05:45 PM
Slowhawk's Avatar
LS1Tech Sponsor
Get rid of the stock MAF/MAP and put in a 2bar,have it tuned with that and your all set.
Oop's,just noticed it is a 98.
Old Aug 18, 2006 | 05:53 PM
BAD FNZ's Avatar
Slowhawk, what's wrong with having a '98? I plan going boosted next summer, what problems are there?
Old Aug 18, 2006 | 05:55 PM
frcefed98's Avatar
Kyle is running a 98 PCM well into the 9's, eights once the wick is turned up.
I'd say he's pushing 1k easily.
MAFT PRO is doing the work. Its a SD set up, but once it's tuned in you can switch from a low boost tune to a high boost tune with a flick of a switch(key stroke) from what I understand.
HPT also has 2 bar SD for 98's and it can be pushed pretty far @15psi and whatever your combo is capable of hp wise.
Once you get it dialed in you can leave the tune alone until you change something like more boost, cam or bigger turbo..then its retune time.
J
Old Aug 18, 2006 | 06:32 PM
KAOS's Avatar
so how much for the two bar setup? and how far on stock pcm no 2 bar
Old Aug 18, 2006 | 07:10 PM
frcefed98's Avatar
You can wing it pretty far on a 1 bar/maf set up, ask Kp.
www.hptuners.com for specifics on the two bar,
www.maftpro.com on their set up.
J
Old Aug 18, 2006 | 08:01 PM
Tiago's Avatar
I made 700 rwhp on teh stock 1 bar setup and stock MAF..then went to speed density.
