AFR 205 or Ported 6.0
Andy
The Afr would be off a car that was N/A and have the smaller chamber but I think I could make up for that with more dish in the piston. The main reason I am asking is I have heard that the size of the port is more important than the actual flow numbers when dealing with forced induction. In this case the 6.0 would have a larger port. OTOH I like the thicker deck of the AFR's as PSJ pointed out. I will be running high boost. Motor will be 348ci.
Has anyone ran both on a 346?
1) Boost measures restriction, so the bigger the valve the better right?
2) If I was going for 700-900rwhp I'd go with the thicker deck heads to minimize the heads lifting under boost.
3) Do the 6.0's blow as good as the AFR 205's?
