power steering delete
Old Aug 23, 2006 | 07:34 PM
code4's Avatar
Default power steering delete
Has anyone here deleted their power steering & mounted the alternator in it's place on a fbod? Is there a bracket for doing this?
Old Aug 23, 2006 | 09:31 PM
LASTLS1's Avatar
6 Second Club Moderator
If you drive your car much it isn't fun!
Old Aug 23, 2006 | 09:47 PM
Boostaholic's Avatar
I have mine deleted and its no problem for me, but I did not move my alternator.
Old Aug 23, 2006 | 09:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run the Madman rack and skinnies and you don't even notice that power steering is gone.
Old Aug 23, 2006 | 10:40 PM
LASTLS1's Avatar
So do I and it's a PITFA. I'm worried that I'm going to bend my steering shaft everytime I turn my car from a stop!
BTW what's the time frame on your car? It was looking good when I was there.
Old Aug 23, 2006 | 11:12 PM
navymitch12's Avatar
my pump leaks so i short belt it around town...have not had working steering for a while and it does get annoying....will be fixing the pump soon...but i put up with it for prob 5mths.....with 275's up front as well
Old Aug 23, 2006 | 11:50 PM
code4's Avatar
Anyone mounted their alternator on the upper driver side?
Old Aug 24, 2006 | 07:25 AM
smokinHawk's Avatar
I made a bracket once for a guy to mount it on the driverside head, he had his PS removed.
Old Aug 24, 2006 | 09:54 AM
kp's Avatar
kp
You must be working out lol, there is quite a difference between power steering and a manual rack even with skinneys.
Old Nov 9, 2006 | 12:11 PM
s1ck s0n's Avatar
would it be fine just taking out the pump? how do you loop the lines or whatever? will it be easy to put the pump back on? im not worried about drive-ability at all i just want to put it back together right if i can.
Old Nov 9, 2006 | 12:15 PM
kp's Avatar
kp
Sure you can just take the pump off and loop the lines, but its very hard to steer unless you swap to a real manual rack. I just leave the PS on mine, with a procharger you cant do the short belt and from what I read it only takes a couple HP to drive the pump..
Old Nov 9, 2006 | 01:14 PM
s1ck s0n's Avatar
ok cool, thanks. did they ever make an f-body with a manual rack? i was thinking i could pic one up from a junk yard or something. i hear the madman rack doesnt work for bigger rims/tires. i want to do 17's with 275's up front.
Old Nov 9, 2006 | 01:48 PM
ty_ty13's Avatar
7 Second Club
wrong... ... i have no power steering and a procharger.... i took an extra idler pulley i had and machined the stand off hex to accept it... now i have an extra pulley to keep it from rubbing... but it works
Old Nov 9, 2006 | 01:57 PM
LS1Tech Co-Founder
KP, manual racks turns 100 times easier than a PS rack that's looped. I could barely turn a looped PS rack.
Old Nov 9, 2006 | 04:51 PM
kp's Avatar
kp
100 times? I doubt that lol. I have had them on two cars so I can be a pretty good judge. They are easier then a looped stock rack (which is what I said) but they are nowhere near power steering like, if it is you may not have any positive caster in your car
ty-ty, I'm not wrong, I just meant the short belt alone wont work. I made an idler pulley off the hex on the lower standoff with a P1SC setup three years ago. I would do it on this car but I cant justify 600.00 for 8lbs and lighter then stock steering components on a 3400lb front heavy car..
Old Nov 9, 2006 | 11:22 PM
ty_ty13's Avatar
7 Second Club
you know im just bustin your ***** KP... you've put together more setups than i've seen ...
i've still got the stock rack and its looped also... im big and strong though
