Universal Intercooler Piping
Old Aug 24, 2006 | 01:27 AM
funnelone's Avatar
Default Universal Intercooler Piping
Has anyone used the universal intercooler piping that they sell on ebay? I'm going to be mounting a TRT intercooler and I really don't want to pay the $550 they want for the piping. If anyone else has tried this please share your experiance with it.
Old Aug 24, 2006 | 07:21 AM
smokinHawk's Avatar
i used it for my cold side tubing on my turbo set up, works great, got the 3" polished and welded it up to what i needed.
good price for what you get.
Old Aug 24, 2006 | 08:16 AM
trtturbo's Avatar
You can do it for less absolutely, but that does include all the silicone, transition 90, step hoses, etc., stainless t-bolt clamps, bov flange tig welded on, bracket made so there is no guess work, & bead rolled pipe.
Old Aug 24, 2006 | 09:11 AM
funnelone's Avatar
Oh yeah from what I have read your kit is compelte and has super nice pieces and I will probably wind up getting it from you. I just want to get some opinions from some people who have done it themselves. I'm sending you a pm right now also.
Old Aug 24, 2006 | 02:30 PM
ABeasst's Avatar
was your piping aluminum? I only have a MIG welder so was looking at getting mild steel.
Old Aug 24, 2006 | 04:50 PM
STALL UP's Avatar
I bought the 3" alum kit and had to tig some of the pipes and then grind down the weld and had them powder coated looks pretty good. I also got the intercooler from e-bay did all my own fab work and got a little over 300$ in the whole thing. last time I logged my iat's where 113-117 under boost and outside air was 102.
Old Aug 24, 2006 | 05:47 PM
Jake@EPP's Avatar
If your doing it for a procharger then we sell a kit for this, its $850 and includes mandrel bent pipes and silicon hose fittings with the good T-bolt clamps.
Old Aug 24, 2006 | 11:34 PM
chance575's Avatar
I dont know how any of this would hold up to boost......check it out though
intakehoses
Old Aug 25, 2006 | 10:56 AM
slick1851's Avatar
Anyone have a link?
Old Aug 25, 2006 | 12:30 PM
smokinHawk's Avatar
yes aluminum, i have an AC/DC tig though
most of the time aluminized is cheaper, so if your using steel and are going to powder coat it get what ever is cheaper, maybe what is thinner if you want to save weight.
Old Aug 25, 2006 | 08:53 PM
97ws6pilot's Avatar
I used the universal piping kit off ebay and the pipe is very good quality and lightweight. I had to buy one extra 90 degree bend to make it all work. I bought my intercooler off ebay also. The hoses that came with the kit are useless. I popped a hole in one of the 90 degree hoses on just 10 psi. I went with some gates hose like procharger uses.
My front mount and all the piping costed less than $300 but it took forever to mock it all up and get it to fit right. Just depends if you have more time or money.
97 WS6 Trans Am, 10psi P1SC FMIC, 224/232ex 113 LSA Comp XE Cam, Ported Lt1 heads, 60# Mototron injectors, 58mm Holley TB, Custom Dual Walbro, Harlan Sharpe 1.6RR, Cloyes True Roller, Rebuilt Stock rods and crank with ARP bolts, -20cc dish TRW forged blower pistons(9.0 comp ratio), Delteq Ignition, Meziere Electric WP, Pacesetter LT's+Dual 3" Cats(No more stinkies), Hooker Catback, Bilstein shocks, BMR SFC's, C5 Brakes, Tuned by me.
http://www.cardomain.com/ride/2373730/1
Old Aug 26, 2006 | 07:13 PM
slick1851's Avatar
Were are you guys ordering them from on ebay?
Old Aug 27, 2006 | 12:06 AM
97ws6pilot's Avatar
Here are some links
http://cgi.ebay.com/ebaymotors/3-Int...23025901QQrdZ1
http://cgi.ebay.com/ebaymotors/4-WID...QQcmdZViewItem
Old Aug 27, 2006 | 07:51 PM
slick1851's Avatar
Thanks alot!
Old Aug 27, 2006 | 08:18 PM
trtturbo's Avatar
I have the intercooler less than that.
$175.00 shipped in the lower 48
shipped same day!!!
Old Nov 29, 2006 | 09:52 PM
CoopDog's Avatar
For the aluminum tubing, what is the reccomended thickness? .060 or .120? It seems that most, if not all of the stuff on ebay is .060. I bought some of that, it just to thin. I certainly won't be welding that, there wouldn't be anything left!
Old Nov 29, 2006 | 09:58 PM
00ls1's Avatar
Possible Scammer - Buyer Beware - Issues Unresolved
shipped same day!!!
got mine from him, awesome intercooler. cant go wrong with it, especially for the low price
Old Nov 29, 2006 | 10:03 PM
Armageddon's Avatar
...with cheese.
I used pre-bent mandrel 3" stock from Summit Racing. I'm sure I spent a little more than the Universal stuff on ebay though. It'd be cheaper if you knew a good welder so you could keep the silicone and the t-bolt clamps to a minimum. That stuff adds up quick!
Old Nov 29, 2006 | 11:19 PM
EGash's Avatar
I've used the ebay material on several cars, however there are some problems. The aluminum pipes seem to be chemically polished, some kind of anodize or coating. This has to be removed on the outside and inside of the pipe before it can be tig'ed. I tape off the end of the pipe to be welded and use red scotch pad to remove the coating, even then the puddle is dirty.
The rubber hoses that come in the "universal" kits are almost always junk, usually just throw that away and use some good reinforced Silicon. I bead roll all the pipe ends so, the worm gear Clamps are ok for low boost < 15psi, but are really one time use only.
There's alot of work in fabbing a nice IC kit for your car.
Good luck,
Old Nov 30, 2006 | 06:35 AM
smokinHawk's Avatar
ya i have the .060 works and welds great, i dont know what your trying to weld it with a stick or something?, my tig did it just fine
also i didnt realy have to clean it up to much or brush it down, just wiped and started welding and it was just fine.
