My PCV Setup PT II
If you have any of the part numbers for any of it just let me know.
Also, where did you get the catchcan?????
The Valve covers are from Nate @ Nasty Performance.
The -10 fittings were extra and welded on. the brand of the breather/catchcan is in the pic. there a non sponsor so u will have to search for there site sorry.
I then bought a 3/8npt to -10an 90 degree elbow for each side...... then 2 -10an straight fittings and 2 90's and i had like 25ft of -10an hose already.
Kyle
Im making my own brackets and mounting them under the cowl.
Making my own plug wires too.
Kyle
thanks for the info on that catch can just placed mine and ran the lines last night def a good product..will be switcing to the valve covers on the other car this winter...but for not i have one line from the z06 valley tray to the can and the other from the passenger side valve cover.
cool post up some pic's.....
Shouldn't the system go into the intake tract(into the Turbo) so it creats a Vaccumm Pull???
Still trying to figure out the PCV setup on my LT1 D1SC setup. I want to run this setup but I just want to make sure it will work before I do.
I see alot of guys switch to the LS6 PCV setup on Ls1 cars. Why would somone pick this setup over the others. Do you still have any type of PCV on the intake anywhere???
Thanks for any help.
