My PCV Setup PT II
Old Aug 25, 2006 | 01:11 PM
NA$TY-TA's Avatar
Default My PCV Setup PT II
Been working on the valve covers and pcv setup.
I know Rob... .I need to clean that damn Alt.
Kyle
Old Aug 25, 2006 | 01:25 PM
2000 Tran Zam's Avatar
Lookin good
I really should invest in a catch can with as much blow by that I get from my loose motor.
Old Aug 25, 2006 | 01:31 PM
navymitch12's Avatar
man i really love the looks of that setup...i think i am gonna end up going with a setup that will get me a little more vac in the crankcase....but your setup looks a lot cleaner...and eaiser to install
Old Aug 25, 2006 | 01:35 PM
dynedta's Avatar
chronic masturbator
ahhh what the hell put the hood down and drive the damn thing LOL ahhh wait i bet it runs like crap with no spark lol, anyways looks killer bro!
Murdock's Avatar
I think I just peed myself. Maybe it's drool.
Great work.
Old Aug 25, 2006 | 01:50 PM
jamnut's Avatar
I have those same exact EBAY valve covers, I haven't gotten to the point of needing a PCV system yet, but yours gives me some idea's.
Old Aug 25, 2006 | 01:51 PM
NA$TY-TA's Avatar
Hey Now your getting ahead of me....
That will be done as soon as i finish making ghe brackets for the coilpacks.
Oh i couldnt drive it anyways.... no axles..... there off being redrilled for 5/8 studs.
Soon....
Kyle
Old Aug 25, 2006 | 01:52 PM
NA$TY-TA's Avatar
I didnt get mine of Ebay i bought them from Nate @ Nasty Performance.
Old Aug 25, 2006 | 02:33 PM
jpat1023's Avatar
Damn!! That looks badass man!
Old Aug 25, 2006 | 02:41 PM
TS6's Avatar
TS6
Looks nice, but its not really a PCV system, correct? Its just a breather system right? Unless you have a vacuum pump I don't see or something. Either way, nicely done!
Old Aug 25, 2006 | 02:47 PM
smoke20's Avatar
where do you purchase the check valves for the catch can..
Old Aug 25, 2006 | 03:02 PM
TS6's Avatar
TS6
What check valves?
Old Aug 25, 2006 | 06:28 PM
NA$TY-TA's Avatar
Yeah basically its a crankcase breather/catch-can setup.
Old Sep 6, 2006 | 10:10 PM
T/A KID's Avatar
I have been looking at Crankcase Evac setups and I really kike this. I hate the factory PCV setup and I was thinking about a catch-can.
I have a 383, Ported AFR heads, d1SC motor should do 650-675RWHP.
My initial thoughts was to run a line from each Valvecover into a Catchcan then 1 line branch off the catchcan into the intake system (between the filter and blower inlet). I know it cost MORE but I would like to run braided lines with it as well with an fittings coming off the valvecovers.
I see you have what I am thinking, a line coming from each valvecover into a Catchcan with a FILTER. Does yours circulate back into the intake Tract?
With the filter on the can I suppose it filters it someway and how often do you have to empty Oil out of the catchcan???
nasty or anyone else can you give me some help???
Old Sep 7, 2006 | 10:24 PM
T/A KID's Avatar
Can anyone respond to this???
Old Sep 7, 2006 | 10:45 PM
ABeasst's Avatar
his does not go back into the intake track. thats the only question I can answer.
Old Sep 8, 2006 | 06:29 AM
Navy David SS's Avatar
I have basically the same set-up. No re-circulation. There is pip-**** drain on the bottom of can. Hopefully you never see that much blow-by to fill up the can. Todate (knock on wood) my can is still clean/empty
David
Old Sep 8, 2006 | 10:02 AM
T/A KID's Avatar
Thanks Guys, I have been researching this alot since I have found out the stock PCV system kinda of sucks, lol. I looked at a lot of systems and this one by far looks like the easiest.
Those look like -10An fittings on the valvecovers, so -10 An fitting on the catchcan too, Seems pretty easy.
Navy David SS Awsome setup I ahve seen your pics before. Are you running the same catchcan, if so where did you get your I need to order it up??
thanks
Old Sep 8, 2006 | 01:20 PM
NA$TY-TA's Avatar
David
Correct...... it doesnt touch the intake track at all......
The petcock drain is here.............
Kyle
Old Sep 8, 2006 | 01:21 PM
NA$TY-TA's Avatar
thanks
That catchcan i use uses 3/8npt to -10an fittings.. fyi.
All other fittings are -10an
Kyle
