Any tricks to drop the pan?
Old Aug 26, 2006 | 05:54 PM
fletchls1's Avatar
Default Any tricks to drop the pan?
I put this here because I am pulling it to tap for a oil return. I know a lot of you have done the same.I have all of the bolts out of the oil pan, and the motor mounts out with the motor jacked to its max but still cannot wiggle the pan out. Any tricks or whats the easiest way?
Thanks
Old Aug 26, 2006 | 07:05 PM
HellRaiser's Avatar
I removed the oil pick up tube and the pan came right out without me having to jack up the motor. It's tricky, but I did it.
Old Aug 26, 2006 | 10:48 PM
MiaSSmaro98's Avatar
how easy is it to remove the pickup?
Old Aug 27, 2006 | 12:25 AM
fletchls1's Avatar
Its more of an issue trying to get the pan to clear the transmission and that bar directly under the front of the pan.......Any way to do it without unbolting either??
Old Aug 27, 2006 | 01:07 AM
Boostaholic's Avatar
With the motor jacked up just a little and someone prying the kmember down a little the pan will pop right out.
Old Aug 27, 2006 | 02:21 AM
2002/Black/SS's Avatar
if i do it i need to take my timing cover off, onbolt the pickup tube from teh oil pump, unbolt the oil pan, lift up the motor (leave it connected to teh motor mounts though) and slid the oil pan out, how do i lift the motor a little? i cant use a jack becuase there is no point ont he motor that dosent have the oil pan under it.......
Old Aug 27, 2006 | 11:05 AM
The Juggernaut's Avatar
With the tubular k member-
loosen the oil pan bolts,remove the big bolts
in the motor mounts,
jack up the motor by the balancer(or use a cherrypicker from the top)
Oil pan will slide out.
Old Aug 27, 2006 | 01:41 PM
fletchls1's Avatar
Stock k member? Are you loosening the bolts before prying it down?
Old Aug 27, 2006 | 02:39 PM
~JOSHUA's Avatar
Lots of people drill (with a techinique) that spares them from dropping the pan...
Last edited by FIREHAWK#608; Aug 27, 2006 at 02:44 PM. Reason: spelling, changed "form" to "from"...
Old Aug 28, 2006 | 12:51 AM
Mike 01WS6's Avatar
They do make special drill bits to tap pans with that drive the shavings out towards the drill rather than having them fall into the pan.
Old Aug 28, 2006 | 07:55 AM
cool u should post up were we can buy this bit to help out members
Old Aug 28, 2006 | 10:58 AM
CP05GMC's Avatar
If the K is what's in the way, then you can loosen the 4 bolts on the K a bit so it drops a 1/2 inch or so and tilts, which should allow the pan to slide out.
Old Aug 28, 2006 | 12:09 PM
tinytimsolderbrother's Avatar
Default damn
that just sounds scary
Old Aug 28, 2006 | 01:46 PM
MavrikTA's Avatar
Yeah, def. need one of these drill bits, because I aint wanting to pull that pan! Where are they!?
Old Aug 28, 2006 | 01:51 PM
Sunset01TA's Avatar
The bits came with vortech superchargers maybe you you could call them . We just pack the bits with grease to pickup the shavings.
