HELP NEEDED!!!! Oil remote pump
Old Aug 29, 2006 | 01:47 PM
Outlaw's Avatar
Default HELP NEEDED!!!! Oil remote pump
I have seen some guys on here that have electric oil pumps on the return line from the turbo to the pan to help pull the oil out of the turbo and push it into the pan. sometimes used for guys with low mount turbos that dont have enough for gravity to take the oil out of the turbo. Whats the best one? Who stocks them?
Thanks guys!!!
Old Aug 29, 2006 | 01:51 PM
67Firebird455's Avatar
Um, I got a mocal pump for my setup, seems to work okay, but getting the PCV setup correctly will make a difference with a scavenge pump, if you boost the crankcase, that pressure makes it difficult for the pump to function correctly in getting the oil back in the pan apparently.
Old Aug 29, 2006 | 02:00 PM
Outlaw's Avatar
I have a external wet sump pump on the preasure side going out, IE like a dry sump pump but where a dry sump pump uses and EXTERNAL oil tank to hold the oil, my setup uses the oil pan as the oil tank.
In the picture below you can see the oil pump off to the drivers side of the motor.. with the turbo mounted as low as it is I am having a problem with the return line filling up with oil and not draining into the pan.
Old Aug 29, 2006 | 02:22 PM
bowtieman81's Avatar
Where did you get a Mocal pump? Sorry for hijacking Outlaw.
Old Aug 29, 2006 | 02:55 PM
Outlaw's Avatar
thanks guys.. i looked up Mocal, and found out that pump is the same pump that tilton carries and is stocked by summit. $179.00
Looks like it should be a perfect pump for this problem
Old Aug 30, 2006 | 03:24 AM
MiaSSmaro98's Avatar
yeah but mocal has 2 styles which one do we need?
Old Aug 30, 2006 | 07:49 AM
Good question, they are slightly different in price but the descriptions are pretty much the same.
Old Aug 30, 2006 | 08:14 AM
i cant find the diffrences
Old Aug 30, 2006 | 08:42 AM
SINISTER's Avatar
im useing the tilon just got it all plumbed up
ill snap some pics and post them
Old Aug 30, 2006 | 08:59 AM
and wats the other model?
Old Aug 30, 2006 | 11:40 AM
Phate's Avatar
Do a search on Weldon or scavenge pump in this Forum and you will find the pump that you need. A lot of the Incon guys bought either Weldon or Puisi scavenge pumps to replace the failing Tilton pumps from their Incon setups. I am using the Weldon pump for scavenge, but not on an Incon kit anymore.
If memory serves it is the same pump that is used for the differential cooling system in the new Vettes.
The Tilton may be fine for your race-only app...but on a street car or semi-street I would spend the extra $$$ on the Weldon.
Awesome car BTW.
Old Aug 30, 2006 | 01:39 PM
SINISTER's Avatar
alos someone do some resurch i do belive that the gear oil pump on a c5 corvetter use's a weldon pump!
Old Aug 30, 2006 | 03:04 PM
any sites?
Old Aug 30, 2006 | 04:03 PM
SINISTER's Avatar
have to get a corvette parts diagram and look at the picture..
almost positive it is the same thing..
Old Aug 30, 2006 | 06:53 PM
Phate's Avatar
It is...it is the same one that I bought. I like the Weldon pump, although it has less then 20 miles on it, you can fit a -10 feed and -10 return on it...which helps if you need to move a lot of fluid. You can also adjust the pressure on it.
Old Aug 30, 2006 | 07:32 PM
SINISTER's Avatar
well hell you can get them pretty damn cheep from gm...if you can get them at cost
Old Aug 30, 2006 | 08:24 PM
Phate's Avatar
I think that I looked at GMpartsdirect and it was fairly cheap...but shipping was ridiculous.
