guys check out this cam
Old Aug 30, 2006 | 08:34 AM
MiaSSmaro98's Avatar
Default guys check out this cam
well several members told reverse splits are good for turbo correct?well then i just found this one any feedback
Stealth II 224 220 .581 .581 116
its an mti cam
Old Aug 30, 2006 | 10:08 AM
bowtieman81's Avatar
I have read that reverse split are really good on more restrictive setups, like log manifolds.
I think in normal truck manifold setups guys lean more towards an equal duration cam. Speed incs popular turbo grind is a 225/225.
However, I bet that stealth cam would perform good for you.
Old Aug 30, 2006 | 10:10 AM
well i do have log manifolds, they are the truck manifolds
Old Aug 30, 2006 | 10:12 AM
Personall, I dont think of the truck manifolds as logs. I think of a log as in where both cylinder banks feed into 1 manifold and then the turbo.
Old Aug 30, 2006 | 10:25 AM
KHShapiro's Avatar
What he said
Old Aug 30, 2006 | 11:09 AM
correct i think the same way as well, but i wanna pick a cam already but not sure which so i go with a zo6 a lpe or this one?
Old Aug 30, 2006 | 11:51 AM
Well, I went Z06 on mine mainly based on cost/hp. I got the used Z cam for 115$, a new cam would be about 350-400. Figured I could get a meth kit for around the difference and make more hp.
But, if I could have found a used LPE or stealth cam I would have bought them.
I dont think you can go wrong whichever one you get. Heck, MM made awesome power with a stock 98 cam. KP made awesome power with a Z06 cam.
Old Aug 30, 2006 | 02:29 PM
2002/Black/SS's Avatar
as u know already i got the LPE GT-7 instead of the ZO6 and the one ur looking at will be louder then both of the other cams
 Michael S. Palmer
Old Aug 30, 2006 | 03:03 PM
loud will be good.remeber i want a small chop to it so everyone who hears it knows its not stock
Old Aug 30, 2006 | 03:43 PM
i dont think the z06 or teh LPE cam will give u that, also i actually want the opposite, i want it to be quiet, but then again im going to have a cutout for intimidation
Old Aug 30, 2006 | 03:48 PM
even though it has a 116lsa it should be more loud
Old Aug 30, 2006 | 04:31 PM
engineermike's Avatar
Reverse splits are over-rated.
My cam is 224/236-114.
Mike
Old Aug 30, 2006 | 04:52 PM
Tiger2o69's Avatar
I have an f13 on a 114 I have to start looking for a cam..
Old Aug 30, 2006 | 04:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
My new 800-1000rwhp cam is a 236 single pattern.
If I was doing a 500-800rwhp combo, I'd probably go liker 225/225 on the lower side, and 230/230 on the bigger side.
116 lsa's will idle nice, but you have to pick your cam specs based on what you are looking for.
Old Aug 30, 2006 | 05:00 PM
Tiger2o69's Avatar
hmm 230/230?
So how would a 230/232 595/585 114 work with an sts kit?
Old Aug 30, 2006 | 05:31 PM
why are they over rated?
Old Aug 30, 2006 | 05:37 PM
67Firebird455's Avatar
its an mti cam
That's the same cam I decided on. Sold my LT's and went with 01+ Manifolds and stock Y. Haven't run it yet, but I'm hoping between those changes it will spool the ***-mount better.
Old Aug 30, 2006 | 05:44 PM
let me know
Old Aug 30, 2006 | 05:47 PM
Tiger2o69's Avatar
are your exhaust pipes wraped?
Old Aug 30, 2006 | 07:01 PM
Going to be... Haven't gotten the motor together yet, grenaded the last one. Decided to run a stock Y, which I believe is 2.5", and then go to 3" at the I, into a bullet (which I had before) then into the turbo and then dual outlet (one on each side) with probably 3 or 4" sewer pipes (to cover the turbo/wastegate).
