guys check out this cam
Old Sep 1, 2006 | 06:45 PM
  #41
84camaroturbo's Avatar
leave well enough alone that is exactly what i am thinking. mine sounded all motor until it hit boost then people would ****. i am going to put my $350 to something else instead of a cam.
Old Sep 2, 2006 | 08:31 AM
  #42
StingrayCrazy's Avatar
Originally Posted by FIREHAWK#608
Here's a soundclip of a 236/236 on a 112 LSA through an open y on an Incon system. It's the same cam that I made 421 rwhp N/A with. I just didn't feel like changing the cam right now.
Firehawk, that sounds very cool I hope that cam makes good power because it's similar to my 281XER 232/234 112LSA and that’s the sound I was after. I'll be using a modified TV81/TV71 its a 81/108mm compressor with a 95/76mm turbine wheel .96ar T6 housing with the 5" dump Y'd into two 3" exhaust pipes.
Awesome build, It looks like your walking the fence between show and go
Old Sep 2, 2006 | 11:16 PM
  #43
MiaSSmaro98's Avatar
hey guys check out this reverse split,should it sound a bit choppy?
227/224 .569/.563 114 LSA what do u think i want a reverse split to help out the back pressure understand
Old Sep 3, 2006 | 01:32 AM
  #44
engineermike's Avatar
Do you really think you'll see a difference in power between a 227/224 and a 227/227? I've seen engines change less than 2 hp from adding 15 deg of exhaust duration.
Mike
Old Sep 3, 2006 | 07:59 AM
  #45
its not power wise, there several members that know i want a small daily driver chop to it.and this looks good and it has a 114lsa and its a reverse split so it will help out with the backpressure
Old Sep 3, 2006 | 09:19 AM
  #46
. . . a reverse split so it will help out with the backpressure
That's what I'm saying. . . do you really think that a 3 degree reduction in exhaust duration will do anything to help you?
Old Sep 3, 2006 | 09:42 AM
  #47
GrahamHill's Avatar
People often put too much thought into the camshaft (imho).. and nothing else so be careful. Less is more sometimes.
Old Sep 3, 2006 | 09:46 AM
  #48
well im no expert im going by what i have read.so what wil be good for me?
Old Sep 4, 2006 | 06:25 PM
  #49
fastbasser's Avatar
You call 5 shops and will get 5 different answers. I think all want to make their "mark" in the industry. Only one suggested a reverse split. I believe it makes little sense since we are FORCING air into the cylinder.. In theory or "my opinion", more duration on the exhaust side makes sense because exhaust is being removed "naturally"...
Note, this is only my opinion. Time will tell how my motor runs when it is completed..
Old Sep 4, 2006 | 07:34 PM
  #50
Bird-Of-Prey's Avatar
I posted something very similar to this a few weeks ago and got virtually no reponse. What I did get was everyone saying go with a reverse split. I was not happy with those answers as they were just to generic. It seems nobody really has an answer to this question because there are to many variables involved.
So then I posted in the advanced section and what a thread it turned out to be https://ls1tech.com/forums/advanced-engineering-tech/541215-cam-turbo-questions-about-lsa-icl-dcr.html
I then posted again in this section for everyones input and again got 0 replies https://ls1tech.com/forums/forced-induction/544604-please-look-thread.html
Bottom line: I went with the exact cam that MiaSSmaro98 is talking about. It's a Thunder Racing cam 227/224 .569/.563 114 LSA. At this point I don't care if it's a great cam, a bad cam, or what ever. I'm tired of the cam debate in FI. It's going in PERIOD.
Old Sep 5, 2006 | 10:30 AM
  #51
bird of prey let me know how it works out and can u send me a sound clip when its running
