What does a dying turbo sound like?
I listened close, and used the stethoscope on several items and still cannot really pinpoint it.
Can you spin the impeller by hand and does it turn freely?
It spun freely by hand before install. I am getting more worried it is the turbo, since none of my other accesories were having any problems before this.
I pulled the intake plumbing off, compressor wheel spins freely by hand, and has very little side play. Could not get the wheel to touch the side of of the housing. I guess this is good news.
JA, it is the same kit and nothing got resolved.
Westside, yes I do with a TTi relocation bracket. Why do you ask?
Pull the DP off and check in there as well, but if one side hits both "should" hit.
Hope its something simple like a misaligned pulley.
J
Westside, were you able to fix your problem somehow? Even though I dont like the stuff I wonder if some belt dressing may help?
This is very strange
I guess I this makes me feel better that it is not the turbo.
Also, for some reason after driving the car and getting it fully warmed up the smoking seemed to significantly decrease. Not go away completely, but it did decrease. Anybody have a theory on that?
These turbos are very strange beasts.
I assume you mean my smoking problem? So my problem is not solved then, just covered up. That stinks. What are you guys using for restrictors?
I had the exact same "oh ****, my turbo might be screwed up" thought when I started hearing the squeak at first.
Good luck, try shimming and...if necessary a different alternator relocation bracket.
