not starting right and a P0343 code, what's up?
Weird problem with one week on my new turbo setup. Took like 4 trys to start it. That's never happened before. Check engine came on, and has a P0343 code. I did a search and found some similar posts.
P0343 CMP Sensor Circuit High Voltage
I may have a wiring problem, is the sensor between the firewall and engine? That would be the easiest fix, except for the fact you can't see much in that area.
Maybe the cam bolts got loose. Are these behind the water pump? I've never torn down an LS motor...
Thanks
Thanks
Great thing to keep handy---------- enter the code and press go.
http://www.iequus.com/support/obd2_definitions.php
handy to keep in ya favourites.
