stainless vs aluminum IC piping?
Old Sep 11, 2006 | 07:50 PM
Country Boy's Avatar
Senior Member
Default stainless vs aluminum IC piping?
Which would be better and why? I can get both as a good price. Either will be polished.
Old Sep 11, 2006 | 08:21 PM
DERTY's Avatar
The Bull
Aluminum. It's far lighter and thermally works better with the heat. No need to go with that heavy stuff. Look at Lynch's 10.5 setup and you'll see that even his downpipes are aluminum. I wouldn't recommend that for a street setup, but for the strip it's a killer way to consider dropping a few pounds.
Old Sep 11, 2006 | 11:23 PM
Ferocity02's Avatar
I agree, aluminum is cheaper, lighter, and easier to cut, form, and weld.
Old Sep 12, 2006 | 01:40 AM
longrange4u's Avatar
It also drops heat much better which is what you want on the Charge side
Old Sep 12, 2006 | 11:13 AM
NA$TY-TA's Avatar
I agree with Alum. Thats what we went with on mine.
Plus it polish's easier..
Kyle
Old Sep 12, 2006 | 11:46 AM
T/A KID's Avatar
I have 3 J-bends from Performance E Curve and the material is Aluminized Stainless Steel. What could I use to polish it. What do you guys usually use on Aluminum.
Old Sep 12, 2006 | 11:48 AM
bowtieman81's Avatar
Is there any problem with the aluminum corroding from the heat/moisture? If not, then I would go with aluminum over stainless.
TchargedLS1TA's Avatar
Scotch-Brite pad.. I forget what the technical term is for them when used on a grinder, but any kind of scuffing pad that is softer than the aluminum..
Old Sep 12, 2006 | 12:41 PM
FastKat's Avatar
If the temp of the air going through the intercooler piping is lower than the temp under your hood, you're going to be heating the air in the piping. If the temp of the air going through the intercooler piping is higher than the temp under your hood, you'll be cooling the air in the piping. Which is usually the case?
Old Sep 12, 2006 | 12:49 PM
Got Me SOM's Avatar
what???
Old Sep 12, 2006 | 12:55 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
I think the air time in the pipe is so small that either will be fine. Aluminum will absorb heat faster than stainless but on a street car both materials will achieve the same final temp. Aluminum in lighter and can be polished but will oxidize and you would have to maintain if you where going for the polished look.
Stainless Steel once polished it stays looking good.
I do not think it will matter, use what ever you have laying around.
Ricky
Old Sep 12, 2006 | 01:06 PM
lo_jack's Avatar
Fastkat is bringing up heat rejection vs. insulation as a determining factor on IC pipe material (and to a degree then thickness). Sounds like an undergrad paper.
If the air in your FI system is colder than the air under your hood, you would want to insulate the system air from heat absorbtion. If it is warmer, then you want to shed heat from that air with heat rejection into the engine bay.
The implication is ambient underhood temps have a corellation to IC pipe material and thickness, since they will both attempt to average out.
Not really sure if it would make much of a difference.
Old Sep 12, 2006 | 01:32 PM
FastKat's Avatar
Thanks for filling in the details there... I kinda got lazy and didn't explain everything in between the lines.
I think a more practical way of looking at it is heat soak. Is your under hood intercooler piping going to heat up from engine heat, actually causing the air flowing through them to heat up? I think the aluminum will transfer the heat faster than stainless, but then again I would say that the amount of heat would be very small. However if/when I put an intercooler pipe next to something hot (exhaust manifold, turbine, radiator) I will use a heat shield.
Old Sep 12, 2006 | 03:00 PM
Senior Member
I may just go with the stainless. I can get it free Free 99 works for me.
Old Sep 12, 2006 | 03:01 PM
Senior Member
Ricky
Thats what I was thinking also, but Im no pro at this stuff.
Old Sep 12, 2006 | 03:46 PM
Got Me SOM's Avatar
you could get that wrapping to keep the piping from heating up, summit sells it, but it looks ugly.
wasn't sure what you mean before.
Old Sep 12, 2006 | 09:04 PM
raymond mckinney's Avatar
Carl how u been doing? And cheaper isn't always better!! What's going on with the Hot Rod? U trying to beat me J/k at least mine sounds better with ur old exhaust on it!!
Old Sep 13, 2006 | 06:09 AM
Senior Member
Whats up bro! Long time no see. Beating you never was a problem.. lol
Cheaper is better for this broke *** redneck boy
