high hp auto guys inside please...
Old Sep 12, 2006 | 01:30 PM
black98ws6ta's Avatar
Default high hp auto guys inside please...
I took my car to a dynojet dyno this weekend and started tuning for power. The set up is as follows:
408, eagle crank, callies rods, weisco 32 cc dish pistons
completely stock 317 casting with dual springs
244-446 .630 .630 115 lsa cam
Gmpp intake manifold with 105 mm tb
t4 percision 88
truck manifold kit 4 inch downpipe
air to air intercooler
tial wg and bov
I am using hp tuner 3 bar, with 160 lb injectors, and driver box for them, and dual intakes for fuel. I am having some problem with everything but wot fueling but I will save that for another thread, lol.
The car is doing several things that are confusing me, and I wanted some opinions. It made 720 rwhp on 14 psi, then a peak of 850wrhp at 20 psi. The dyno runs at 20 psi seems very very short and the car is still building boost. It barely hit the 20 psi mark just at the rev limiter, my dyno graph looks like that of a supercharged car it makes peack hp at peak rpm.
I am thinking with a 400 and converter that the dynojet just isnt enough to load the car, and because of this it spools late, and the dyno pull is very short. Maybe even that the car is pushing through the converter mixed with it being on a dyno jet.
My options are to either strap it onto a mustang dyno and see what it does, or take it to the track and see what it does there.
I would also like any input on the power that it is making, and the dyno situation. I guess the power is close to what I was thinking, but I was going to try more boost for the racegas final number.
Old Sep 12, 2006 | 01:34 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Neat, got a dyno sheet to post? What converter do you have?
Old Sep 12, 2006 | 01:38 PM
I can probably get it scanned and post...it is a bradco converter.
Old Sep 12, 2006 | 01:48 PM
Turbo LS1 SS's Avatar
i'd say get some better flowing heads and that thing would be making stupid power.
still great tho
Old Sep 12, 2006 | 01:50 PM
Set-up is kinda of thrown together to have something to race this year...
Old Sep 12, 2006 | 01:53 PM
y2khawk's Avatar
We haven't put a "high hp" turbo car on the rollers in years. Engine dyno and/or track tuning only.
Old Sep 12, 2006 | 01:59 PM
Because of potential problems like mine? Do my thoughts seem possible?
Old Sep 12, 2006 | 02:16 PM
CarolinaWS6's Avatar
what stall do u have
Old Sep 12, 2006 | 02:19 PM
SSilverSSurfer's Avatar
screw the dyno like y2khawk said and hit the track
Old Sep 12, 2006 | 02:23 PM
y2khawk's Avatar
I've only ever used an eddy current dyno (mustang) for my turbo stuff. The one time i had my car on a dynojet just for fun (still a 6 speed at the time) it had trouble building boost early. So much so i tweaked the controller to fill in the curve, hit the street and saw 3 psi more peak that before.
Not to mention we could never keep my tires from spinning on the rolls, slicks or radials, people in the back or not. It got to the point the whole deal would freak me out Then again, this is all in the 1k+ rwhp range.
Have you had it on the street at all? Is the boost rise more indicative of a turbo then?
Old Sep 12, 2006 | 02:26 PM
FormulaFire's Avatar
That cam is a big boy. I have sort of a similar setup(391 LS2 t4 88) and I am in the process of switching from a t56 to an auto. So I'm def interested in what is gonna happen with yours.
Old Sep 12, 2006 | 02:59 PM
Yes, I should have mentioned that. It sent me sideway from a 3rd qear roll very quickly. I am just looking for some reassurance, I know things will be fine when it sees a mustang dyno/track.
Its not that it doesn't build boost quickly on the dyno either....just the dyno beats the turbo to the end, lol.
Old Sep 12, 2006 | 04:47 PM
Dont know why this one didnt turn out good, but the torque it makes looks better then the higher hp graphs
Another shot of that same graph....
This one has a/f.
This one is versus speed. I think the data is skewed because the car never seen above 7,000 rpm and the dyno sheet shows higher. Can anyone make any sence of this?
Old Sep 12, 2006 | 05:08 PM
TchargedLS1TA's Avatar
You need to throw a load on that thing. Your turbo will make more boost quicker if you have more load on the vehicle. Not to mention that cam your running probably isnt waking up until about 4k rpm
Old Sep 12, 2006 | 06:56 PM
After looking over the graphs, it seems to me the converter is slippin badly. Both at 721 it goes 115 mph and 841 rwhp the car only goes 107 mph. This is with a th400 in 3rd gear, 4.10 gear, and 28x10.5 w's. By my calculation with no converter slip it should go 142 mph at 7 k and 132 mph at 6k, and the dyno rpm is obviously off from that of my cars tach.
Old Sep 12, 2006 | 07:01 PM
Got Me SOM's Avatar
car sounds like it will be a beast when its all sorted out. good luck..
no problems with heads lifting ?
Old Sep 12, 2006 | 08:14 PM
engineermike's Avatar
What size converter do you have? I was running a 9.5", but we could never get it tight enough. I'm switching to a 10.5" to get more holding power. My combo isn't nearly as stout as yours, so I would imagine a 9.5" is out of the question for you.
Mike
Old Sep 12, 2006 | 08:49 PM
longrange4u's Avatar
Am I the only one that thinks 160lb injectors are too much for a 88mm turbo?
onfire's Avatar
Coal Mining Director
DynoJets + unlocked TC's = screwed rpm. I had my rev limiter set at 6500 and the DJ showed 7200rpm. I just scale my rpm to "actual".
What rpm on the tach did you hit the gas?
Old Sep 12, 2006 | 09:32 PM
Nope, the car is around 8.0-1 and had conservitive timing, 93 pump for the 721 and c16 mix for the 841.
I know they are too big, I went on the fact that 96's will be right at there limit, and the shop said they could get 160's to work. I will be redynoing with 96ers, unless there is a low 100 lb injector out there.
Mike
In all honestly I dont know the size of the converter, I trust the converter builder due to his reputation. I believe he needs to give me a tighter one
They were operating, I was just standing close and watching things, I believe by the graphs he hit the begin dyno button and the gas at the same time so 3500? I would have tried some footspooling or something to get this thing to show me some torque. I believe I didnt ever see the shiftlight which was at 6600, so im guessing he was in the 6400-6500 range and the dyno on the 841 pull is showing 7700
