~LOW budget turbo build~
PMed!!!
Turbo
WG
BOV
IC
guages
pillar
fans
Fuel pump
injectors
rails
fuel fittings/lines
oil lines
silicone
t clamps
catch can/PCV mods
maniflds
heads (or at least springs/pushrods)
down pipe/muffler
TUNE TUNE TUNE
Tranny upgrades
drive shaft
rear end upgrades
tires that will let you feel what you spent thousands on
just off the top of my head. Thank again budget man!
PMed!!!
Give me about 3 months.
okay so you say your gonna take 3 months and not spend over 3k. okay. cool. now is that just the turbo kit or does it include supporting mods like fuel and tunning etc.?
Turbo
All Fittings and clamps
Feed and Return lines
Piping
Waste Gate
boost guage
A/F guage
Boost Controller
Intercooler
I/C Piping
Pushrods
Valve springs
cam
Heads
42lb inj
fuel pump
clutch
tune
I think that is just about what every other kit comes with....except for the fact I get to choose all my own parts and its about half the price
Turbo
Piping
Waste Gate
boost guage
A/F guage
Boost Controller
Intercooler
I/C Piping
Pushrods
Valve springs
cam
Heads
42lb inj
fuel pump
clutch
tune
should be interesting. I guess you could do it. but I wouldn't skimp on the clutch though. Turbo
Piping
Waste Gate
boost guage
A/F guage
Boost Controller
Intercooler
I/C Piping
Pushrods
Valve springs
cam
Heads
42lb inj
fuel pump
clutch
tune
If not how much do you think I could build one for, buying used, off of ebay, classifieds, doing most the work myself. etc etc etc
no such thing...
yeah you can save boat loads iif you got the skill to do it your self..but parts still cost what they do..do it right the first time...and you wont end up spending needless expenses in the long wrong fixing the cheep **** you bought
6L manifolds - 50-100 bucks
turbo zone kit - 1500 on sale (includes crossover, downpipe, charge pipe to t-body and they'll plump it for alky
MPT70 - Probably find this for about 500 bucks. Otherwise you are looking at about a grand for a T67
wastegate
BOV
TR6 plugs
Fans (pusher) 250-500 easily
Alky control setup - ~500 bucks
HP Tuners or similar with wideband - ~700 bucks
You could probably tune it to run 4#'s without alky on stock injectors and use alky for supplemental fueling up to ~8#'s boost. Ideally injectors and a pump should be on the list too. That'll add about 700-1000 depending on what you go with.
In comparision a dry kit can be bought for $299 and ~$120 for a window switch. That with TR6 plugs and you'll make the same power
You have been PMing me for the last several days... 500-550rwhp will be much more affordable than the 800 you were PMing me about. The reason I gave you the high numbers is that I was in a similar position myself, but sooner or later you will have to break the bank if your target is greater than about 650rwhp. Somewhere around that number is where **** gets expensive.
The thread starter was mentioning a shop that was doing the work for him, so budget is gone right there. Rice Etr, that $2500 you spent is sourcing everything yourself, doing all of the hot-side welding as well... I know that 76GTS is around $1800 give or take by itself... I do not believe any shop would do that type of work for him for anywhere close to what you have in it. Did that $2500 include your bare minimum of supporting bits like boost guage, fuel pressure guage, and wideband with the guage pillar? Did it include the bigger injectors and aftermarket fuel pump?
It's just the ugly truth of FI; it's expensive. ...and enough with the "silver platter" bullshit, I have alot of money into my setup by I WORK A ******* LOT to pay for it. Ask ANYONE on here that actually knows me...
And if there is one thing that you should not even think of going budget with, it's the turbo itself. You get what you pay for, and buying a cheap turbo gets you just that, a cheap turbo. Do you really want to go cheap on something that's going to spin 70,000-90,000RPMs? That's a cheap ticket to an expensive engine rebuild there. Do it right, or do it over.
I tried to go budget by purchasing a used kit. Got screwed on that and ended up spending about as much as the new one to fix/replace components. I thought I could have a good kit that would make 550 rwhp for about 4k$. Not so.
Are you planning to use a lot of that ss autochrome stuff? From others experience I woud not use any of their parts.
I have built budget kits, that cost me in parts under 2k. Now it also cost me 6 months of time, and really was not happy with it in the end.
and I already owned welding and cutting equipment.
It can do done but at what cost?
I hope your happy with the end results.
Latest build on my own so far 3k in parts and still buying strong.
Ricky
50 bucks for a set of gibson truck headers.
Cut up an old MAC header i had laying around
560 dollar turbo off of a greyhound bus.
used 46mm wastegate
ebay front mount.
50 dollar used vortech mondo bypass
and i built the kit using steel exhaust pipe.
The welder was given to me by a family member who passed. Everything else to support the kit is where I had to spend the money...gauges, WB, allky kit, injectors, fuel pump, tuning, rearend, cage, subframes, etc. Of course i am not factoring the week it took me to build it and the time to source the parts.
FWIW...I got my turbo for a steal....I paid just under a grand for it new from the 3rd owner.
