Ngk Tr-6
Old Sep 14, 2006 | 05:18 PM
MiaSSmaro98's Avatar
yeah but around wat level will the tr-8 be needed?
Old Sep 14, 2006 | 09:56 PM
nitrorocket's Avatar
I have not heard of people needing a tr8 untill 25+ psi. I run the tr6 gapped at .040.
Old Sep 14, 2006 | 10:39 PM
so how can i pick at wat to gap the plug
Old Sep 15, 2006 | 08:35 AM
cablebandit's Avatar
i will get the full explanation today but Steve Petty told me not to be using a projected tip plug.....he was shocked that we used the tr-6s....supposed to give me what he feels is a better alternative today and explain his reasoning using my 317 heads.
Old Sep 15, 2006 | 02:36 PM
let us know
Old Sep 15, 2006 | 03:04 PM
67Firebird455's Avatar
I ran TR6's gapped at .030" also. Never had a problem blowing them out, although I ran a max of 8psi.
Old Sep 15, 2006 | 03:05 PM
so gap them at 30 40 50 60?
Old Sep 15, 2006 | 03:08 PM
bowtieman81's Avatar
I thought I saw a rule of thumb to decrease plug gap by .010" for every 100 hp increase. But, that was with nitrous.
Here is the spark plug reference in the nitrous section:
https://ls1tech.com/forums/removed-locked-thread-graveyard/456380-spark-plug-reference-chart.html
FWIW, I have mine gapped at .040" running 7-8 psi. The only problem I have is a miss on cylinder 8 between 1000 and 1500 rpm only. It just popped up yesterday, so have not investigated it yet.
Old Sep 15, 2006 | 03:24 PM
V6 Bird's Avatar
Originally Posted by KLRWS6
Theres actually a colder plug than the tr-6. NGK makes a tr-8 plug, thats what i have been running in my car boosted
NGK doenst make a TR8...its a NGK 7173 and its a racing plug.
Old Sep 15, 2006 | 03:26 PM
V6 Bird's Avatar
Its not a matter of need guys. Its a matter of safety. period. Less chance of heat soak on a NGK 8 then there is on a TR6. A glowing plug has more chance of lighting off the incoming mixture like was stated causing pre ignition IE knock retard.
Change to a cooler plug like the NGK 7's, 8's or 9's etc and decrease the chances of the plug ever glowing and better yet not pre igniting an incoming mixture before the PCM actually tells it to spark.
Old Sep 16, 2006 | 10:03 AM
JMBLOWNWS6's Avatar
Im going to buy these Mike. And Im going to run them on the dyno back to back and see the results. Stay tuned! Ill have results in about two weeks max.
Old Sep 16, 2006 | 10:09 AM
  #32
i keep a look out then
Old Sep 16, 2006 | 04:25 PM
  #33
https://ls1tech.com/forums/showthread.php?t=456380
If that was the case, I would have .000" gap!!
Old Sep 16, 2006 | 09:33 PM
  #34
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've been running TR8's, and the new turbo combo runs an equivalent plug that the AllPro heads require.
Old Sep 17, 2006 | 03:35 PM
  #35
Julio's Avatar
30 PSI on tr6's gapped at .032
Old Sep 17, 2006 | 04:07 PM
  #36
so wat gap size will be good for 7psi
Old Sep 19, 2006 | 02:27 PM
  #37
s10ls's Avatar
did he ever give you an alternative?
Old Sep 19, 2006 | 03:01 PM
  #38
yes they did. They said the projected tip was a hot spot waiting to cause detonation. i was told to run a R5671A-7 or 8 since i am trying to push the incons. I will try them and see how they do. I have a set of tr6s sitting here if they dont work out. They wanted me to run a -8 or -9 heat range but said to go 7/8 since i daily drive the car.
Old Sep 19, 2006 | 03:16 PM
  #39
V6 Bird's Avatar
its hard to run something that doesnt exist dont you think?
Old Sep 19, 2006 | 03:17 PM
  #40
V6 Bird's Avatar
thats the same **** ive been talking about for quite awhile when these threads pop up.
