superchargers pro&cons
Forged 346, 6.0L heads, mild turbo cam, 8.5 CR, meth, T-76 at 15 psi, 3.42 gears... What do you predict it'll make?
If you go to RevX, don't forget to take a gander at the ride.
How do think the YSi and F-1SC stack up against each other?
I think the ATI unit would make more power cause it blows more cfm than the YSi.
Only thing with the ATi is nobody has figured out how to run on an airfilter with that blower. You have to mount it down low. With the YSi I can mount it on top, I can use it with my aftercooler setup or run it with a front mount and still be able to use the stock lid location for filtration.
I'll definitely take a look at your car, are you gonna put a 6 or 8 point in for safety?
While I'm not at or even shooting for the 800 HP level that the original poster asked about, I can tell you that both the ATI D-1SC and Vortech V9G kits for LS1's are very streetable, make good power, and seem to be a heck of a lot more reliable and low maintenance compared to most turbo setups.
I knew this kind of thread would get the SC and turbo guys to square off. It always does. I love FI in general, so I'm not throwing stones at the turbo crowd. I'm just happy with my SC's.
This car will never see a track (Well, I'll say probably never), and is being set-up for the street... Although, I have heard of some tracks around here that are pretty slack with the rules.
You're not entirely stuck on Centri's and TT's... There is a KB Twin Screw out for the Vette... But it does require another hood that they include.
For F-body's, there are centrifugal set-ups all over the place. The kits are reliable and proven. However, if I had a Vette with all the other options for it, I wouldn't waste my time with them, JMO.
With meth or race gas and a manual trans, maybe.
Or spray it.....
Here is a link to this car. Bob
http://www.exoticperformanceplus.com...Car.php?car=40
