C5 or Firebird
Shawn
I have a TTi Stage X kit, FWIW.
The 800hp+ TTi X kit path is well defined if you want to go that route and George will point you to the path.
Rick
gives me a funny feeling in my stomach. Sure enough there is another alfa male ready to drop the hammer. We size each other up, fat tires, fat rims, raspy exhaust....
I know it's coming, the hammer's ganna drop!
Seeing that car 65 car lengths back in 4 seconds is worth all the time, money
and chunks of life we put into out forced induction f-bodys.
Street car / drag car - go F-bod (bad *** muscle car)
Street car / road race car - go z06. (no doubt the superior all around car)
I agree with Steve... think about us guys you wanna leave behind in RPM
but i to was torn between the two an di had it settled on a c5 vette was ready to sign papers but went to slp day way back when in orlando flordia and i watched a pretty built up yellow z06 tag the wall at the same speed you did..flippy flip it tossed turned and spun saved by the cage in the car....
but i herd it tagged the wall cause of someting in the irs snapped..came home drove and picked up my TA...
yeah it could happen to any car but yours was cause of poor track prep and maintance..
so street car yes but i can see you staying away from the track!!
On a more practical level. You know the Bird. All the mistakes you've made on your previous F-Bodies you can avoid with this one. The vette is going to be more expensive to experiment with and there will be areas, like the IRS, rear mounted tranny and all the suspension that you will have to figure out from scratch. That can lead to expensive mistakes.
Stick with the 6-speed bro! Can beat it on the highway.
Best of luck Dave.
Mike
thats what i thought and when i looked at this car as it was being towed away it had the "Beefed up parts" per say...but never know
i say stick with the sold axel can find f buckets a dime a dozen
I know they are not as fancy as the C5 or C6's, but it does have the front mount tranny, it has a cockpit feel like no other car out there, it handles very well, it is light, they are affordable, and it would make for one hell of a sleeper.. I can vouch personally...
not alot of them out there, but.. you do already have the LSx platform so its hard.. but for a built dart block up to 434" for around 3600 bucks it solves alot of the head lifting issue, bolts right in and you can run the BS3 with a CPC setup and make some seriously big power with some 18* or 15* heads... and an available matching single plane intake manifold.. I am building a solid axle rear end for mine that can be switched from the motor back from IRS with the stout 6 speed ZF6 transmission, unbolt it and disconnect the brake lines and unbolt the batwing and roll the tranny and rear end out from under the car and slide the built TH400 auto attached to a ford 9" rear right on in and bolt it up to the new lader bar brackets and attach the coil overs to their new brackets.. I plan on having this switchable in about 3-4 hours start to finish with minimal hardships in the process.
it would give you the best of both worlds, touring with the M6 tranny which have proven to take a hell of a beating and hold up phenominally, then strap in the track driveline. hell a 4L80E built is possible with the BS3 controller built in. I am not too far away and would be happy to help with the fabrication of the turbo setup as well!
Just throwing out a 3rd option.. a few more turbo C4's can't hurt the world!
PS.. if ya find a nice 95 6 speed car.. no more worrying about OBD2 inspections..
just find a place that is cool with the visual and roll on!this chassis DOES lend itself to a great racer as well as seen below..
http://jobyteknik.homeip.net/corvett...LHowie490.mpeg
http://jobyteknik.homeip.net/corvett...Howie4904.mpeg
http://jobyteknik.homeip.net/corvett...LHowie500.mpeg
Chris
