meth users, what size injectors are you using??
Mightymouse was doing something like that @ 220 psi i believe
here is a meth calculator for Excel http://incontt.net/stuff/methanol.xls
Every motor is different. What works for you may not work for someone else. As there are toooooo many variables. Like oil inside the motor, compression, head flow, turbo/SC/blower, IC sizing, outside air temps, etc etc etc.
And then is type of system whether its a fixed pressure or progressive.
HTH
