Relocated alternator guys: fuel rail interference?
Old Jul 18, 2006 | 05:00 PM
RW99's Avatar
Question Relocated alternator guys: fuel rail interference?
So have any of you running the relocated stock alternator (e.g. SmokinHawk bracket) had problems with interference from the fuel rail?
My LSX intake and FAST fuel rails won't allow the alternator to fit where it's supposed to on the bracket.
I'd appreciate it if anyone using the SmokinHawk bracket could post up with the type of intake and fuel rail that they are (successfully) using.
Thanks in advance,
Rich
Old Jul 18, 2006 | 06:09 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by RW99
So have any of you running the relocated stock alternator (e.g. Slowhawk bracket) had problems with interference from the fuel rail?
I'd appreciate it if anyone using the Slowhawk bracket could post up with the type of intake and fuel rail that they are (successfully) using.
Thanks in advance,
Rich
I don't have a bracket?You are probly talking about the Stainless works bracket.It does work but you have to cut back the aftermarket fuel rails.
Old Jul 18, 2006 | 06:20 PM
RW99's Avatar
Whoops, my bad, that's the SMOKINHAWK bracket... post has been edited...
Old Jul 19, 2006 | 08:28 AM
smokinHawk's Avatar
i run speed inc rails on mine with an ls6 intake, not sure how different the fast ones are.
you have to trim the plastic cover on the back of the alternator.
also you might need different fuel fittings. i use the right angle pipe to hose thread, meaning NO pipe to -AN then a -An to hose.
pic ac1 shows the fuel rails and fittings.
Attached Thumbnails Relocated alternator guys:  fuel rail interference?-alt.jpg   Relocated alternator guys:  fuel rail interference?-ac1.jpg
Old Jul 19, 2006 | 08:56 AM
snketr's Avatar
Can you give more details on your 2nd pic. That mount looks promising. I'm giong to be starting on one soon and that looks close to what I was thinking.
Old Jul 19, 2006 | 10:55 AM
smokinHawk's Avatar
ignore that bracket in the second pic, i was just trying to show the fuel fittings.
the alt bracket mounts to the passenger head
here is the fuel fitting i used
http://www.jegs.com/webapp/wcs/store...tegoryId=10019
Old Jul 19, 2006 | 03:03 PM
snketr's Avatar
I know, I was just trying to stir up some **** to get more pics.
Old Sep 21, 2006 | 10:28 AM
RW99's Avatar
Just to complete this thread: the Smokinhawk bracket with a stock alternator will interfere with FAST fuel rails.
An alternative that works are the CPR rails: http://www.lmperformance.com/5682/43.html
Rich
