Which low CR heads?
Old Sep 26, 2006 | 07:11 PM
NYTHAWK's Avatar
Default Which low CR heads?
Alright guys, I'm totally new to the FI scene. I just bought the Vortech system with aftercooler (9 psi). I'm looking a decent set of heads to slap on to lower my compression to around 9:1 so I can run more boost in the future. Any suggestions? Right now I'm basically stock, mods are in sig. TIA
Old Sep 26, 2006 | 07:30 PM
JAvenger007's Avatar
LQ9/317 (6.0L) heads. I cant remember which models but I think theyre on 01-05 trucks. Bigger chambers ie lower compression and being OEM castings they sell cheap on ebay. they flow a little better than stock as theyre closer to ls6
Old Sep 27, 2006 | 07:58 PM
NYTHAWK's Avatar
Cool, thanks for the info JAvenger!
Anyone else?
Old Sep 27, 2006 | 08:08 PM
jimmyblue's Avatar
Moderator
I think you'll still be at about 9.5:1 with the LQ4/LQ9 ("317")
heads. But you could do some chamber work and up the
volume some more, maybe use a thicker gasket and get
close to your goal. If you were going to hire porting done
it might be a small incremental cost to get them done nice
and matched for volume etc.
Old Oct 2, 2006 | 01:19 PM
MavrikTA's Avatar
I was wondering the same thing. Wouldnt ported LS6 heads, essentially be the same thing with better runners?
