SLP 402 with ATI ProCharger D-1SC at 16 psi of boost = 757 rwhp on Mustang Dyno!
#42
great numbers, espically on a mustang dyno. The only complaint i have is the fact it has a big wing and lambo doors. But then again when you put almost 800 at the wheels you can do what you want.
#43
Originally Posted by 2fast02TA
Would you be holding back the motor a lot if you run a D1SC with stock heads
#45
We ran this T/A the other night. Muncie Dragway does not normally provide much traction on test and tune days, but it didn't do too bad out of the hole. This tranny does not want to shift though! I missed fourth gear on the run above, and I missed second gear on the other two runs! I never could get the car into fourth gear on the run above, and coasted through in neutral, which explains the lower mph in the 1/4 compared to the 1/8 mph... (Left Lane)
This car would be much quicker with an automatic! Bob
#48
Originally Posted by SRZ
Hey I like the gull wing doors. Tight spaces that crap comes in handy.
#50
Originally Posted by THE LAST Z
Does the front mount intercooler help more to make this power than the 2 smaller ones?
#52
Originally Posted by TS6
Is the timeslip supposed to be posted up there? All I see is a red X, what did it run?
The car ran a low eleven in the 1/4, costing much of the last eight mile. Bob
#56
Originally Posted by Y2KCAMARO
do you sell that front mount intercooler as a kit
I have added it to our "products" page. Thanks for inquiring! Bob
#59
I own this car now it is Canada I imported it in 2014 I had to tune the fuel to the air here and on our mustang dyno first pull with good afr it pulled 758rwhp I cam across this thread and thought I would comment s I was reding I started to realize this was my car anyway this car is getting the much deserved f1a and the t56 is coming out and a glide is goin in should be interesting I cut a 1.59 60ft with the car and ran a 10.89 at 132mph in Canada also proud to say the lambo doors are off thank god hated them shooting for 9s and 900ish rwhp
