Turbo timing...
Old Oct 3, 2006 | 09:30 PM
Country Boy's Avatar
Senior Member
I know with N2O that youre supposed to take out 2*s per ever 50HP of N2O.
Old Oct 3, 2006 | 09:41 PM
bowtieman81's Avatar
Yep, this is true.
If it were me to get the car running safely I would back the timing down in all cells 2 degrees from stock, then make the timing under boost 10 degrees. From there you can gradually turn the timing up and see where the thresholds are.
Old Oct 4, 2006 | 06:06 AM
cablebandit's Avatar
i agree...start overly conservative. Gives you the freedom to check everything out...making sure you arent lean...overboosting...smoking...missing etc
