Turbo timing...
Old Sep 28, 2006 | 01:56 PM
Country Boy's Avatar
Senior Member
Default Turbo timing...
This might be for the PCM section, but I figured it get more answers here. How do you start building a timing table for a turbo car? Right now I loaded in a stock timing table, but I dont want to drive down the road, hit 10psi and have 26*s of timing... something tells me that wouldnt be good . Anyone have a rough table I can have to start with?
Old Sep 28, 2006 | 02:19 PM
TchargedLS1TA's Avatar
I think 2* timing removed for every psi of boost is a good safe place to start
Old Sep 28, 2006 | 03:00 PM
bowtieman81's Avatar
I took the stock table from an 02 Z06 and dropped it down to 12 degrees in the boost areas. Worked good, had no detonation.
I had planned to make a thread about how I am tuning my car since we seem to have a lack of turbo tuning info.
Do you have hptuners Carl? If so I can send you a couple .bin files to look at.
Old Sep 28, 2006 | 03:27 PM
Senior Member
yeah, HPT! Send them to countryboy@tampabay.rr.com Thanks bro.
Old Sep 28, 2006 | 03:32 PM
JMBLOWNWS6's Avatar
Are you in SD using HP tuners or you just runnning the maf ?
Old Sep 28, 2006 | 03:33 PM
Senior Member
SD, no MAF
Old Sep 28, 2006 | 04:24 PM
JMBLOWNWS6's Avatar
Then you will need something like I have. 2 bar correct?
Old Sep 28, 2006 | 04:34 PM
I will send them your way tonight. Keep in mind I am using the MAF (no 2 bar setup for me yet).
Old Sep 28, 2006 | 05:12 PM
Senior Member
yep!
All help is welcome. Ive never tuned a FI car before.
Old Sep 28, 2006 | 10:15 PM
Boostaholic's Avatar
I run 17deg wot
Old Sep 28, 2006 | 10:18 PM
LASTLS1's Avatar
6 Second Club Moderator
Originally Posted by Boostaholic
I run 17deg wot
Me too.
Old Sep 28, 2006 | 10:22 PM
nick y's Avatar
19* here
http://s22.photobucket.com/albums/b3...rrent=atco.flv
Old Sep 28, 2006 | 11:22 PM
LTLHOMER's Avatar
21 here at 20+ lbs of boost. I ran 25 deg at 15 psi peak (14 average) and went 151 though but that was on c16.
Old Sep 29, 2006 | 12:12 AM
slow's Avatar
What kind of grams/second do you guys see under boost?
One could use a 3d regression program to generate the timing tables based on the factory table.
Ryan
Old Sep 29, 2006 | 12:13 AM
LTLHOMER's Avatar
Ryan
Why would you want to do that? lol
Old Sep 29, 2006 | 04:47 PM
Schantin's Avatar
I limited my timing to 18 degrees WOT. Usually is good...unless I get stupid and pull multiple back to back high speed blasts. The added heat then gives 1 to 2 degrees knock retard. I worry most about the AF. I traded some HP for "safety"...running 11.0 ratio at WOT. Even then the instantaneuos reading spikes register as high as 12.2. I played with the timing a bit in the WOT ranges....but it didn't seem to make much difference on the AF ratios bewteen 17 and 20 degrees.
BTW, this is on 5PSI w/ mods listed below. Tuning is SD w/ HP tuners. It's a work in progress (that's on hold while I'm in the desert......)
Old Oct 3, 2006 | 08:58 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Isn't there some sort of rule of thumb, ie. to reduce timing by 2 degrees for something? Not sure if it was each lb of boost or something else. Of course if you ran 15 psi you'd have to cut the timing back to 12 psi or run race gas.
Old Oct 3, 2006 | 09:04 PM
Senior Member
If it were 2*s for every 1#, then at 15psi, youd be in the negitive timing trying to take out 30*s..
Old Oct 3, 2006 | 09:15 PM
hellbents10's Avatar
LS1Tech Sponsor
remember to have some correction for inlet air temps too. That is one of the most important things.
Old Oct 3, 2006 | 09:26 PM
LS1Tech Co-Founder
Yeah, I can't remember where there was this interesting discussion about timing.
I see a lot of folks running mid to high teens timing on pump gas.
