Turbo Car Restrictive Exhaust
Can and probably will run an electric cutout right off the DP.
Suggestions anyone, im talking full setup from the DP back.
Size of tubing, muffler suggestions etc.
Rob
I will be the first to say that I know next to nothing about a turbo setup on an LS1...for the record. Let me know if you need this moved.
No cat btw.
Rob
No cat btw.
Rob
3" DP, dual 2 3/4" pipes, out to the rear of the car] w/ 2-Dynomax Ultraflows, 3" dump. The difference in HP was 3, at the wheels.. closed vs open. The sound level is very low. So low, in fact, that folks thot it was a Monte Carlo...
I'd set yours up w/ a 4" dump, and 3" piping, w/ muffs..Pipes out to the rear of the car...
I'm running a 3.5" exhaust with a Magnaflow muffler and it's surprisingly quiet, especially at full throttle. However, it definitely still has a rumble at idle if you stand behind it.
Mike
