Ran the TT Chevelle on Tuesday.
All runs were on 93 octane, and my cars has a 3850 lb raceweight. I made 2 passes with only 10 psi and went 10.80 @ 130 even on both passes. Went through the traps at about 6600 rpm.
I reset the boost up to 18 psi and ran out of gear, I had it set to 10 psi in 1st gear, 12 psi in second, and 18 psi in 3rd with the E-boost.
Due to a bad launch and having to pedal it the pass was pretty bad. I launched with a 1.90 60', my 1/8 mile was a 7.0@112, and my quarter was 10.55@ 138.
1.9 seconds before I tripped the clocks, I ran out of gear and was on the rev limiter at 7000 rpm till I let off right before I finished, hit the brakes just as I crossed the traps. The car sounded like it had gunshots coming out the tail pipes and was blowing flames out the tailpipes also! I luckily have it on video so I was able to time exactly when I first hit the rev limiter to when I actually finished the pass.
I was pretty dissapointed that I did not get to see how much power the car put to the ground by my trap speed.
I need to get some 3.08 gears for my 3 series carrier and some new tires. I have 3.42's now but did not count for converter efficiency. I also am trying new tires seeing that I has to try to keep the car straight the entire pass!
I hope the 3.08 gears are not weaker then my 3.42's, the ring gear is much thinner. I guess I will see.
I have never been to Orlando in my life. Why do you ask?
doyou have adjustable shocks? set them stiffer so it plants those tires down.
I am gonna have to hook up my 2 step. I cannot get a solid launch rpm and boost down. At anything more them 0 psi it will blow the tires off with the trans break. It is that much harder without a drag slick to launch. What is funny though, it before the turbo setup, I used to launch 1.60's, now I am super lucky just to get 1.80's! Dang turbos!
Killer setup!
